Since the seven pin on our T@Bs is wired for back up lights. It seemed like a good idea to put some on.
![](https://us.v-cdn.net/5021717/uploads/editor/nc/zr916ocedfft.jpg)
![](https://us.v-cdn.net/5021717/uploads/editor/3g/qimbpzxfj1i3.jpg)
Especially for those late night camp site arrivals. Easy cheap addition cost about $15 for the lights I chose plus some wire I had around the shop. Our TV was also wired for backups to the 7 bin. Difficulty scale about a 1.5 out of 5.
2016 Jeep Cherokee & 2017 T@B Outback
Sterling, VA
Ha, and I keep askin' myself, "what's he gonna come up with next?"
Great job dale!
Goes where it's towed to by 2017 Subaru Outback
2011 T@B
Rockingham, NC
This one??
https://www.amazon.com/Lightahead-degree-rotating-disco-silver/dp/B00O17QZRA/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1493756109&sr=1-2-catcorr&keywords=battery+disco+ball
We had a bunch of folks with them and had taken over a remote park loop. Corn hole (bean bags) with puck lights, disco lights going and Coleman lanterns lined like a run way from one game board to the other. Good times.
To make it work first check the center contact on your TV 7 pin. With your TV backup lights on take a test light clipped to a ground, touch the center terminal. If it lights than you can preceded to wire trailer.
Step 2 On your trailer follow the 7 bin cable back to where it enters a black box that is attached to front trailer cross member. Remove the 2 screws holding cover. The first terminal from the driver side should be your ground. The third terminal in the box has only 1 yellow wire attached to it. That is your + or positive. Run a wire from each of those terminals to your choice of backup fixture. That's pretty much it.
To test, you can use a 12v test light and test the vehicle side. Here's a diagram showing which pins to test (see "7-way RV Standard" and "Outside" picture).
Put the test light on the "Ground" and "Reverse LIghts" pin. If you get light, you're all set.
(NOTE: Before you test this, you must have someone in the car while the vehicle is in reverse, if the engine is running. Be sure to set the parking brake and have them hold the brake petal to prevent any movement!)
2014 T@B CS Maxx
Martha Lake, WA
Here's my low tech version,. I carry one of these in the tow vehicle and it sits perfectly in the Outback cargo rack while backing up. Handy light to have it you use other Milwaukee cordless tools.
www.amazon.com/gp/aw/d/B00G3T1FO2/ref=mp_s_a_1_3?ie=UTF8&qid=1493757995&sr=8-3&pi=AC_SX236_SY340_FMwebp_QL65&keywords=milwaukee+lantern
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
Yes It is made from 4" drain pipe from HomeDepot plus 2 snap on end cap.
