Back up lights for after dark arrivals
Eric aka: Lone Wolf0 -
Dale (aka Dr. T@B-en stein) can take parts and pieces and make them into something very cool!
3 -
Dale, here is some pics of what I did with your backup light mod to my T@B, its as bright as one LED fog light. It should be plenty of light. Thanks for the great idea!
3 -
Nice work as usual.
- Hash T@B Fun
Very slick. I just bought my wife a flash light.
2016 T@B M@X S grey/red 16 Foot Airstream, towed by 2014 Jeep Grand Cherokee V6 4x4, Central Connecticut
2 -
The flashlight works great until they start using it to swat at bugs. Then that's when it gets really interesting when you are trying to back into your camping spot, with the light going every which way!
2 -
@Pop-T@B, Yep, gave Liz 2 flashlights to use......only once!
Looked more like a laser light show from the driver's seat!
Eric aka: Lone Wolf1 -
Ya know Pop-T@B, you could back up that truck to the edge of a cliff and warn boats off the reef.. no lighthouse needed.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
Can you ever have to much light? You should see the led flashlight collection I have, I have some you could almost use for airplane runway lighting
@Dalehelman I was looking at your backup light solution and the 7 pin access box you used for wiring. I want to wire a wireless backup camera (that just doesn't sound right) to the back of my T@B but can't find a good place to wire into the running lights for power. If I can get wire long enough, could I do the same thing you did with the backup lights and wire it to the connection for running lights?2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX0
I'm not even going to worry about installing backup lights. I have hard enough time backing up in broad daylight. There's no way I am going to try backing up the T@B in the dark.Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner1
I'm with you on that! I am hoping a backup camera will let me see what is behind me while driving. And it may even reduce the number of backing up attempts below 5 or 6! 2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX0 -
If I had seen this tread before, it would have cut down in my hands on trailer wire reaserch.
Should have tought about hitting the search box. But imagine that I did show my mod to my work partner who as a fitfh wheel trailer, and he was wondering why I would need such light. I guess he is not in the exploring mode like wost of us are.
When I did this, I was sure that the trailer frame was grounded, so to make it perfect, I will have to run ground wire and maybe add 1 or two led light per side.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Les Escoumins and Petite-Riviere-St-Francois QC0 -
I go for the quick, cheap and easy route on this one. Actually I read about it here and it works very well! Put a flashlight or lantern on the ground on the drivers side back where you want to end up, and use it as your guide ( @ericnliz its quieter than a spouse, too!). I put a luci solar light on the ground by each shed door when we had to back it there in the dark.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red3
I don't have the backup lights for parking. They are there so I can see the bears.
- Hash T@B Fun
3 -
@Dalehelman, The trick with the bears is coordinating the hand (paw) signals!
Eric aka: Lone Wolf2 -
ericnliz said:@Dalehelman, The trick with the bears is coordinating the hand (paw) signals!
*groan* 2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1
