Softer LED bulbs
foxden
Member Posts: 148
I appreciate the efficiency of the LED bulbs but I am not really liking the blueish light they produce and would prefer something that is more like a soft white. Has anyone replaced those interior bulbs with something softer? I saw a good discussion about using filters to dim them but I would like to replace them if possible. Not even sure if LED comes in anything other than the blueish color.
2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX
I'm guessing the LEDs in my Tab are more of the "bright white" (3000K+) instead of the "soft white, (2700K)" I'd love to replace mine with a lesser wattage, too.
The gels and filters do work, to a point, but are a bit clunky.
And, don't even start me on "Color Rendering Index." If a bulb for my home doesn't tell me what the CRI is, I don't buy it. I want the reds/green/blues in my house to be, well, red/green/blue.
If you search "warm white LED" with your bulb size I think you will find what you want.
I would agree they are very harsh. I added this set of LED tape lights last fall and they have a soft white setting that looks just like incandescent soft white bulbs. they are dimmable and they also have a full range of colors if you want to change it up
Thanks @Pop-T@B I will look at those. I had hoped for a replacement solution but decided to try something else that was mentioned on the forum. I had a soft yellow chalk paint and I put a thin coat around the inside of both reading lights and the overhead light. Wiped it off with a damp cloth and then repeated the process. You can't actually see that there is any paint on it but it left just enough yellow residue to give the lights a softer glow. The downlight part of the reading lights still has the bright white/blue color but the overall appearance is much warmer. Don't think it will work for the one above the sink so I will work on the replacement search for that one.2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX0
I use one or two Luci Light Candle after dark. I love the soft light(sorry, no pics!). It is solar and I got them on Amazon.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
Those look nice. I just bought a few of the luminaid lights similar to that for outside but I think I would like the Luci Candles even better!2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX0
@foxden, this gives you a better idea. 2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
@Homebodyatheart I just put in my order for them! I didn't want the flickering one (candle simulation), but got a plain and then one that changes colors.
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0 -
@Ratkity congrats! They are so easy! Every morning I set them in the kitchen window for the day, bottom side up, to charge. Couldnt be much easier! Let me know how you like thrm.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
Soooo, You set them in the window upside down for donations?
Oh, They're solar!
Eric aka: Lone Wolf1 -
I also got the skull and spider one... Muhahahahaha...
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2
