db_cooper said:Any water that gets in will drain to the gray water tank. The AC puts out condensation normally and it is routed to the gray tank. It's important to be level when running the AC so it will drain properly
RollingBnB said:Lexan cut to same size as vent, 1/2" foam around edge and J-bolts hooked to fins inside vent cover.
Loosen the 2 wing nuts and turn J=bolts to remove. Water and dust proof.
Ratkity said:RollingBnB said:Lexan cut to same size as vent, 1/2" foam around edge and J-bolts hooked to fins inside vent cover.
And it doesn't blow off like mah redneck one!! Looks fabbo
