wind and rain entering A/C vent
mowenski
Member Posts: 3
Is there any concern about the rain entering the A/C vent if there was enough wind?
This is for my T@B Max S (2017)0
I have never had rain enter the A/C vent.Verna, Columbus, IN
There has been a recent thread on vent covers and how to install them. Mostly for insulation improvements, rather than rain. https://tab-rv.vanillacommunity.com/discussion/4825/how-to-install-a-c-vent-cover#latest2015 T@B Max CS-S Silver and Black
Goes where it's towed to by 2017 Subaru Outback0 -
That is good news - I have not used the camper in pouring rain but was curious if others have had any issues - Thanks!0
Any water that gets in will drain to the gray water tank. The AC puts out condensation normally and it is routed to the gray tank. It's important to be level when running the AC so it will drain properly2015 Max S Outback | 2010 Xterra -- Retired
Like db_cooper sez, there's a tray in the bottom of the AC compartment that should collect and drain any water in there.
A cover might be a nice addition to stop the wind though. The wind seems to work its way in.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
I thought it drains to the ground ...by a black tube?0
db_cooper said:Any water that gets in will drain to the gray water tank. The AC puts out condensation normally and it is routed to the gray tank. It's important to be level when running the AC so it will drain properly
@db_cooper, the A/C Drain goes down through the bathroom wall, through the floor and drains to the ground. It does not drain into the gray water tank.
For proof, remove the seat cushion for the bench on the driver's side next to the bathroom wall. Remove the plywood seat (you'll need yo remove at least one square drivevscrew that holds the plywood in place) and you should be able to see the clear hose coming from the A/C unit and going through a hole in the floor.
There are many discussions on the forum about the drain tube.Verna, Columbus, IN
vent cover is a good, inexpensive fix.0
Thanks for the clarification. I thought I'd read somewhere that it went to the gray. Either way a little water coming in that vent isn't going to hurt anything. Driven in a lot of rain here in the PNW and not had any issues.2015 Max S Outback | 2010 Xterra -- Retired
Clear cover I made
2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
Don't leave us hanging, how did you make such a fine looking cover?
Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado0 -
Lexan cut to same size as vent, 1/2" foam around edge and J-bolts hooked to fins inside vent cover.
Loosen the 2 wing nuts and turn J=bolts to remove. Water and dust proof.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az2 -
RollingBnB said:Lexan cut to same size as vent, 1/2" foam around edge and J-bolts hooked to fins inside vent cover.
And it doesn't blow off like mah redneck one!! Looks fabbo
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0 -
Ratkity said:RollingBnB said:Lexan cut to same size as vent, 1/2" foam around edge and J-bolts hooked to fins inside vent cover.
Hasn't blown off yet.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
I built this to keep out the cold & water. I glassed & epoxied the wood. The door slides down when the A/C is in use. Art2019 TaB 320 S Boondock Edge1
@gulfarea - would you post instructions? When you say it slides down, how is it held in place? Close up pics would be helpful too - thanks!Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
You never really travel alone. The world is full of friends waiting to get to know you!0 -
mick I have the cover sliding in a grove, I have magnets holding the slide in the up position and stops in the down position so the cover cannot fall out on the road. The sliding door would hit the window if it were open but I never run the A/C with the window open anyway. I put a bug screen on the inside of the box. Art2019 TaB 320 S Boondock Edge1
RollingBnB, where did you get the nuCamp decal?
