We need to shorten our chains and change out the clip/ring that connects to the hitch holes. I know they should be short enough not to drag, but long enough not to prevent a sharp turn. How do you decide the length before we start cutting? Trial and error? Should we just leave them long and add something to tie them up in transit?
Also, the clip that came on the end of the chains will not allow attachment to the hole on our Draw Tight hitch. Anyone else with this problem? What kind of clip/ring did you replace it with and what works for you?
The break away cable has a loop at the end and no clip, so we need to add a clip there too. If the hitch is bolted to the van frame, is it acceptable to attach the break away cable to the hole in the hitch where the chains attach? Seems like a ring should have been included with the cable.
0 ·
2014 T@B CS Maxx
Martha Lake, WA
I believe that is why holes along side the receiver are large and elongated.
