Mixing Valve Blues
So now it is our turn to adjust our mixing valve.  Now that we have dried up the flood caused by adjusting the screw right out of the hole...we are back to the beginning.  I set it to what I think is the coldest setting (more "-").  My question is this - we do this to allow a nicer shower.  Should we not adjust this mixing setting when the Alde is set at "boost"?  That way we would be starting with the hottest water and step down from there.  What has everyone done?
  • RollingBnB
    RollingBnB Member Posts: 322
    We used a digital temp gun to set the mixer so the water temp going in was as close to the same as coming out. This way you get to use as much hot water as you need. Ours started to squirt too so I just screwed it 1 turn and called it good.
    2020 Tiffin Open Road
    2020 Nissan Versa Toad
    Alan & Patty
    Southern Az
    RollingBnB:  Did you set the Alde to "boost" when you checked the temperature?
    Ok, so we discovered that the Alde Bypass valve was open and allowing more cold water to mix in!  Just got a temperature of 110 on propane. On the boost mode on propane only, the temperature is 130.  That should be fine.  Will be camping tomorrow night and test the shower comfort then.
  • ericnliz
    ericnliz Member Posts: 4,437
    @SAM, Good catch on the 'ol by-pass valve! That's a "sneaky" one! ;)
  • RollingBnB
    No, got 137 w/o boost. At that temp can't run just hot at the sink.
    Alan & Patty
    Southern Az
  • joyce3251
    joyce3251 Member Posts: 3
    I see this is a couple of years old, but I had the same problem with twisting the valve right out.  Now I can’t figure out how to get it back together! No diagrams of the inside of the mixing valve. We have tried a number of combinations and it’s not working.  Wondering if I missed a piece in the geyser that sprayed out at me.  It can be put back together right?
    2018 T@b 400 - 2018 Ford Explorer Ltd
    Yes, it can be put back together, but, if you are struggling, then I wonder if a spring or something shot out with the water.  Does anyone have a picture?
  • joyce3251
    Here’s what came out. The knob screws into the black piece but the other two pieces do not fit in any combination. Sticks out too far. Sorry this pic is so huge.
    Here is a diagram.  You don’t seem to have part #4, but this is the arrangement of how they should fit.
  • joyce3251
    So now I will go back and look for that part...thank you!
  • DougH
    DougH Member Posts: 1,110
    This forum is so awesome!
  • ChanW
    ChanW Member Posts: 3,171
    My thought exactly!
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • BrianZ
    BrianZ Member Posts: 1,770
    The title of this topic sounds ripe for a talented guitar-playing songwriter to sing around the campfire at a T@B gathering.  Picturing lyrics about springs & water flying everywhere.
    ScottG Administrator Posts: 5,696
    I'm curious if anyone has just removed the mixing valve. I suspect if I had a later model T@B that might be the first thing to meet the tubing cutter. After all, both the sink and the shower feature their own integrated mixing valves.  ;-)
  • jkjenn
    jkjenn Member Posts: 6,425
    edited May 2019
    Was just think we need a parody of, "All the Single Ladies" for all of the solo women camper threads, lol...it could be followed by "Mixing Valve Blues."
    Well, that mixing valve seems to trip up every owner and it has occupied a large amount of real estate on the forum!  We need a poem outlining the typical “no hot water” “did you adjust your mixing valve” advice😜
  • jkjenn
    Seems fitting of a haiku.
  • BrianZ
    edited May 2019
    Adjust mixing valve?
    How much should I turn the screw?
    Duck! Parts are flying!
  • jrslad
    jrslad Member Posts: 21
    Just bought a new 400. Playing with systems in my driveway. I cant seem to get the hot water to remain at a constant temp. with the tap on full hot I get hot, cold, hot, cold etc. Turned the mixing valve to max hot, same thing. Would the experienced please give me some direction. I have the boost checked on the system selector and the temp set to full, although it returns to half after about a half hour. Working with propane only, I plan to be at National Parks so no electricity for the most part so I need to get the propane only thing down.
    John & Michelle & JD (Just Dog) 2019 T@B 400 Boondock LTE  towed by a 2017 Toyota Highlander v6, (flat land only) or a 2017 Tundra v8 (when going west)
    edited May 2019
    Turn the little screw.
    Turn it back and curse the world.
    Break out the Sawzall.
  • BrianZ
    edited May 2019
    @jrslad, here's a topic related to your issue..
    http://tabforum.nucamprv.com/#/discussion/8784/hot-water-no-hot-water
    It also has link to an explanation & "how to" for adjusting mixing valve.
    Here are some things that can affect water temp..
    Are your plumbing water valves set properly (no Alde bypass)?
    Is your cold water source very cold? (May need mixing valve adjustment)
    Are your Alde menu controls set appropriately (no continuous glycol pump setting)?
    Is your glycol pump speed set too high, either via menu or physical switch on pump?
