We bought our 2016 Tab used and the cutting board is warped. Is that common?
Could we fix it by oiling it with mineral oil. wrapping it in syran wrap and setting a cement block on it for a few days... or soaking it in water and setting a cement block on it... or something else... or just buy a new one...
Mickey & Terri
2016 Max S
Kalamazoo Michigan
0 ·
My solution to the warping of the T@B (or T@G) cutting board is to keep it in the original bubble pack wrapper and buy a similar sized man-made cutting board for daily use. If you have used the care and feeding instructions above, the original wooden cutting board can be used as a serving tray, but washed, allowed to dry and then stored out of sight of the sun and other light. The changes in humidity and temperatures are some of the causes for the warping.
Why are the cutting boards warping? They are thin wood, they have not been treated with mineral oil and the above instructions for care and feeding have not been implemented.
Yes, you can buy other more expensive butcher block treatments, but I like the inexpensive mineral oil. I've even used mineral oil as a finish on cherry salt and pepper grinders I made. It's a non glossy finish that helps repel water, and is moisture resistant.
CAUTION: MINERAL OIL, NOT mineral spirits......that would cause lots of problems.
Compliments of Ye Ole Woodworker.....me
2011 T@B
Rockingham, NC
Previous thread here:
http://tab-rv.vanillaforums.com/discussion/comment/52619#Comment_52619
https://www.amazon.com/gp/product/B001FB6TSK
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
Thanks to all who had input in this suggestion.
Ok.. warp-proof cutting board.. redneck style... go git some sheet metal, ya know, the stuff you has hangin' around by the shed. Gotta use the flat stuff, not the rolled up tin stuff. Make template. Git couzin to get his welding torch out or his favorite cutting tools. Make sure the edges are filed nice and round. Epoxy a thin plastic food grade cutting board top to the metal (upwards, not downwards). Make gasket to tightly go around the metal and fit snugly into da sink. Now youse got a cutting board that kin also act like them old fry pans - jes whack your unsuspecting, cupcake snitching spouse out da door when he or she is in da way (careful of the screen or you'll get a second whack).
https://www.tapplastics.com/product/plastics/cut_to_size_plastic/hdpe_cutting_boards/346
Averting a hihack, HDPE has a high heat distortion temp and would not expect it to warp in a T@B environment. (Do not put in oven however)
Goes where it's towed to by 2017 Subaru Outback
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
P.S. You missed some icing on the coffee cup handle!
3/8" thick HDPE
10 7/8" x 14 7/8"
1" rounded corners
