You could make a template out of paperboard and take it to TAP plastics.dsatwork said:Someone should cnc one out of cutting board material and sell them to tabbers. I want a gray one.
I haven't heard of HDPE warping in normal use, even in hot climates.Ratkity said:Mine warped too. It didn't help that the faucet had an ever-so-slight drip and then add heat. I never used it except as extra counter space. Thinking about the food grade plastic ones, I wonder how they hold up to the heat as well?
That's cool to know! It's something I was wondering about the cutting boards. Good to know my coffee cup won't melt it (not that I use it as a trivet - just caffeine deprived).Marceline said:I haven't heard of HDPE warping in normal use, even in hot climates.Ratkity said:Mine warped too. It didn't help that the faucet had an ever-so-slight drip and then add heat. I never used it except as extra counter space. Thinking about the food grade plastic ones, I wonder how they hold up to the heat as well?
https://www.tapplastics.com/product/plastics/cut_to_size_plastic/hdpe_cutting_boards/346
I think that if NuCamp switches from wood to HDPE they will probably make something nicer (more like the wood board), but for now here's what I did:SAM said:Marceline, can you share your order so we can replicate it? Thanks!
