Alde Wall Controler no power
BirdieJaneBirdieJane Member Posts: 237
woke up, no power to the Alde Wall Control. Push Control on button nothing. Ideas? I.e. Fuse?
aka BirdieJane towed by Quinn
  • BirdieJaneBirdieJane Member Posts: 237
    Crisis averted you may all now sleep well, changed a fuse:-) But also discovered my Alde system was not plugged into the 110 power supply.
  • ScottGScottG Administrator Posts: 5,618
    Glad you got it solved so quickly. Which fuse was blown?
    Note that while not being plugged into 120VAC will prevent you from using the electric heating elements, that should not affect the control panel or other electronics--those run exclusively on 12VDC.
    There's a chance the 110v cord did it's final escape and popped the 12v fuse in doing so... never know with those gremlins. Very glad Birdie got it figured out! T@B University badge for midnight troubleshooting!!
    That happened to us once after driving on a very bumpy road and I've heard of a couple other incidents. First thing to check!
