'Ya ever think of tryin' Beano?
ChanW said:Yeah, our poor pup hates smoke alarms, absolutely freaks him out, and he set it off one night...
The only way to stop the darn thing was to lift the bed and disconnect the wires, all with grog in my brain.
I don't remember the part about whether it was in a truck-stop/rest-area, so I couldn't run out in my skivvies (PXL style) and put the poor dog in the truck while I dealt with it.
There ought to be a switch, darn it!
Photomom said:I THINK this is the correct manual. There are instructions for hooking it up. You might verify this is the same one you have. http://www.atwoodmobile.com/manuals/gasalarms/LPCO MPD 31298 11.07.pdf
As for why, two words: dog flatulence.
It would be a simple matter to cut the black ground wire and connect it to a rocker switch mounted on the bench. Of course, you would have to make very, VERY sure the detector is on if the propane is on.ChanW said:Yeah, our poor pup hates smoke alarms, absolutely freaks him out, and he set it off one night...
Photomom said:It would be a simple matter to cut the black ground wire and connect it to a rocker switch mounted on the bench. Of course, you would have to make very, VERY sure the detector is on if the propane is on.ChanW said:........
