I agree, I travel by bicycle, motorcycle, or small rv, I really like the freedom it gives mePXLated said:Awhile ago I experienced the opposite - Guy next to me had the biggest, fanciest RV I've seen (four slide-outs) and was pulling a trailer with a four-passenger Polaris Razer four-wheeler, a Mini Cooper and a 2x3 foot cast iron griddle. - No thanks, too much work.
To avoid discharging the TV, (and to avoid the weight of the jump start box), if I leave the TV connected to the trailer for the night I pull the fuse in the charging wire from the TV battery to the trailer. I have considered installed a solenoid on this line that would only allow current to flow if the TV ignition switch is turned on, but haven't yet felt the need to spend the $100 for this device.Deltaboy59 said:Well I've found ...and a jump start box for those times you run the TV battery down...
I asked the dealer about a solenoid when I was picking up my T@b and they told me that they never install them because they can go bad and ruin the battery. Has anyone heard of this before? Truthfully, I didn't know if they were just giving me a line or if it was actually a potential issue.Mercator have considered installed a solenoid on this line that would only allow current to flow if the TV ignition switch is turned on, but haven't yet felt the need to spend the $100 for this device.
My auto mechanic advised again an electronic battery isolator as they can cause problems - particularly in dropping the voltage and current to the trailer battery. Instead he recommend a mechanical solenoid (basically and on/off switch) which he advised was cheaper and not prone to problems and drops in voltage and current.jkjenn said:I asked the dealer about a solenoid when I was picking up my T@b and they told me that they never install them because they can go bad and ruin the battery. Has anyone heard of this before? Truthfully, I didn't know if they were just giving me a line or if it was actually a potential issue.Mercator have considered installed a solenoid on this line that would only allow current to flow if the TV ignition switch is turned on, but haven't yet felt the need to spend the $100 for this device.
https://www.youtube.com/watch?v=cXlVVgsp64c . Hope that helps. Not my strongest suit, but I just keep the mutilmeter manual and can figure out from there.
mickietucs said:Question related to basic needs: the list says a wrench to tighten the ball mount. Is there a particular kind of wrench to get? I was in Lowe's today and wondered if any wrench would do. Would a socket set come in handy and if so, would it be a standard set that will work on the bolts found on T@B? Thanks all!
I bought this one: http://www.amazon.com/gp/product/B000CQOIV4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
