You are looking at around 92# of extra weight if the freshwater tank is full and anything extra behind the axle and to the rear will also contribute to and create trailer sway. Since the trailer is a higher profile, passing semi's does create a draft and crosswinds encountered after passing will create some instability when towing. One of the keys as noted above by others is to add weight to the tongue since owners tend to store heavy items in the benches behind the axle to the rear and inside galleys of the clam shell units. Not to mention that traveling faster than the rating for the tire (most are rated at 65 mph) creates heat build up on the tire sidewall and can result in a blow-out and a rollover accident.Smullis7 said:I usually have the fresh water full, but I do have some food and clothes stored under the rear bench. I'll have to check to see how level the T@B is when towed. It can't be off by much, because I have slept in it, etc. while still connected many times and don't feel like I'm leaning. :-)
https://youtu.be/GfeyBxuIZOU?t=25
https://youtu.be/nd-hUX8memY?t=143
) ... I've become pretty good at guesstimating the tongue weight.
