Still excellent tracking.
!!!! I'm not saying that they are not built for highway speed and it is because of that you should slow down, I'm saying that you should slow down because you tow a trailer. Reaction to fast manouver with load is not the same. You are a truck driver, then you more than anybody esle should know about that. And you aslo know that the way you load is organized will after drivability and possibility of quick manouvrebility. You must have pulled an empty box trailer over a bridge with a strong side wind. Were you keeping highway speed or slowing down so you would not flip on your side. And why do so many state and province ask vehicules with trailers to go slower than simple cars and trucks? On an other forum, guys were all cranky about the fact that the bigger the TV, the better for stability. Example given, a guy ad lost every thing in an accident while pulling is toy holler cause he had caught a draught from a semi. The trailer was like 40 foot triple axle with a truck or heavy buggy in the rear garage. They finaly said that he was probably doing 80 mph when it happen. Not sure that his load was well center.Tabfortwo said:I've also been towing trailers and driving big rigs for the past 30+ years. And I'm sorry but the trailer should be engineered to tow at freeway speeds. That being said I drive about 10mph under the speed limit and with the trailer new from the dealer with nothing added tire on back and completly level this thing is all over the place. I removed the tire and the little plastic thing on the bottom of the rack sway almost completely stops. I'm sorry but this seems to be an engineering nightmare. And I can't get nu camp to return a call so far no impressed.
I've got a CDL too and have towed large loads, heavy equipment, large/small trailers and in all types of weather and road conditions over the course of 40+ years and respectfully disagree with your "design flaw" statement and claim. If your trailer is swaying it is most likely because (and as noted by others) your tongue weight is too light and you need to move more weight over center of the axle and to the front of the trailer. Obviously a spare on the back of the trailer is going to add an additional 60-70 pounds of weight behind the axle and some trailer sway is going to occur unless you properly redistribute the weight or remove the spare, etc. And this is why there are posted speed limits (e.g., why big rig speeds are spelled out and why they require rigs to travel 55 mph on California highways, etc), caution lights/warning signs/safety devices are posted ahead of curves and inclines m/steep grades along roadways to alert and prevent drivers from losing control of their vehicles/loads via momentum and excessive speeds.Tabfortwo said:I've also been towing trailers and driving big rigs for the past 30+ years. And I'm sorry but the trailer should be engineered to tow at freeway speeds. That being said I drive about 10mph under the speed limit and with the trailer new from the dealer with nothing added tire on back and completly level this thing is all over the place. I removed the tire and the little plastic thing on the bottom of the rack sway almost completely stops. I'm sorry but this seems to be an engineering nightmare. And I can't get nu camp to return a call so far no impressed.
Are you referring to rack itself being 11ins. lower? Stand by going out to measure for you.Tabfortwo said:Do me a favor and get a measurement from the ground to the bottom of the rack and to the tire also. Mine is almost 11" lower than the one at the dealer
2017 T@b 320 S
2017 Kia Sorento SXL AWD
