I'm thinking of buying a smart charger. When using it on shore power is it all right that the trailer's charger is also trying to charge the battery or do you need to disconnect the trailer's charger once you buy the smart charger.
Thanks for any input.
2016 CS-S silver and red, 2022 Toyota Sienna Hybrid
Ottawa, Ontario
0 ·
Ottawa, Ontario
I'm sure there are some good theoretical arguments why one method of charging is better than the other, but I'm kinda' lazy when it comes to hooking up the smart charger so I usually just let the converter or the T/V do the job. Anecdotally, I see no performance difference either way.
On the few occasions when I camp with hook-ups, I generally just leave the fully charged battery disconnected.
Ottawa, Ontario
Ottawa, Ontario
Even a fully charged battery may get a bit depleted en route if you are running the fridge on DC. A lot seems to depend on how your tow vehicle's generator output is controlled.
It probably doesn't make a difference if you are headed home, but if you are looking to arrive at the next campsite with a full battery, you may be disappointed regardless of how you charged the battery when you started. There's been quite a bit of discussion on this in some other recent threads.
Thanks for your input ScottG
Ottawa, Ontario
The shore power feeds directly into the 120V breaker panel circuits. One of those circuits in turn feeds the converter, which then provides power to the fused 12V circuits. You might think of the 120V side as being "upstream" from the 12V side.
On our next long trip I'm hoping to get into solar.
Ottawa, Ontario
Word of caution, never coil your extension cord neatly. These cords put off heat (with high draws) and can melt your little neat coil. My BIL did that using a rotisserie outside with a 50 ft 18g extension cord. Oiy, the smell! LOL. I usually carry a heavy duty construction cord (12 or 14g - can't rem). A charger doesn't take a large draw though. That ice maker for your "special drinks with umbrellas" may though!!
Now to shop for a charger. I was gonna buy one for when I bring the battery home for the winter regardless.
Ottawa, Ontario
