I did something stupid and dragged my plug. Has anyone replaced the plug yourself with something like
this? Was the process pretty idiot proof? What tools did you need to get the job done?
0 ·
It's a case of matching up wire colors in the connection box under the front storage box. Hard part is you have to lay on your back and work above your head. At least that's how I approached it. Sort of tight space within the box.
Screw driver to open the box and a nut driver or wrench for the terminal studs in the box.
https://www.amazon.com/CURT-58140-7-Way-Blade-Connector/dp/B001EOWPOA/ref=sr_1_3?ie=UTF8&qid=1500506116&sr=8-3&keywords=rv+7-pin+socket
Cleveland, Ohio
2018 Ford F150 XLT pulling a 2020 T@B 400
LIFE IS GOOD!
I do agree that replacing the entire pigtail with a similar sealed type would be the best solution, but yes, you can replace only the plug. That is what the item you posted is designed for.
We purchased the 8', not sure that the 6' would quite do it neatly and leave slack for turns. Not too much slack as we did the first time. Second was too little and it popped out of connector on car go around a right hand turn. This is the one we purchased.
https://www.amazon.com/gp/product/B0007LL0CO/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I'm thinking about trying this one in the hope that it will be harder to drag.
https://www.amazon.com/dp/B01C5IWQLK/_encoding=UTF8?coliid=I5TSD8LC9F7V&colid=77LZJK08QRLQ&psc=0
We set it up so that the plug can not drag, and is in easy reach. The half inch eye bolt, with a green hose section, provides a convenient handle when moving the trailer.
