Waterproof Toilet Paper Holder
JJandJJ
JJandJJ Member Posts: 11
edited July 2017 in Modifications & Upgrades
Does anyone know if it's safe to drill a couple of small holes here?  I'd like to install a waterproof toilet paper holder?  I have a 2017 Max S
    Be careful if you choose to do so.  Some have had success.  Here are a couple of pictures of the construction.  Not much more than foam.  There seems to be a nice piece of wood on the front driver side wall.  Hope this helps.
  • Verna
    Verna Member Posts: 6,876
    You can put the TP holder on the opposite wall, next to the kitchen. But no screws. Use Gorilla tape or Waterproof Command Velcro strips.
  • JJandJJ
    The command Velcro strips didn't work.  I'll check out Gorilla tape.
  • JJandJJ
    Thanks for the pictures SAM - I'd been looking for something like that
  • Z_G
    Z_G Member Posts: 38
    Use a coffee can...
    JJandJJ - welcome.  It doesn't help that the wood is behind the toilet!  As Verna said, you can always try Gorilla Tape/Command strips.  We use a TP size Tupperware container left on the floor of the BR and do not worry about anything falling off the walls.
  • Verna
    I use a 32 oz Coffee Creamer container with a screw-on lid that has lasted over two years now.
  • ericnliz
    ericnliz Member Posts: 4,437
    The ol' Folgers coffee plastic container works just fine for us. No plans on doing an "open house" of the bathroom area in the near future anyway! ;)
  • Tabaz
    Tabaz Member Posts: 2,420
    Any clear plastic Costco container of cashews, trail mix, pistachios, almonds, etc. works great - until you realize you left it in the TV. That's when you appreciate the toilet being in the shower.
  • gooselady
    gooselady Member Posts: 177
    I use a tank TP holder that I hook on the door, then flip it to the outside when I take a shower.  $8 maybe, easy squeezy.
  • larrygon
    larrygon Member Posts: 255
    Remember to empty the container before trying to put the TP in!  =)
    "Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
    2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
  • Tabaz
    Too funny Larry!  Perhaps someone just needs to invent waterproof toilet paper.  Then we wouldn't need a cover.
  • Z_G
    @Tabaz not sure waterproof TP would be very effective...
    I made a simple wooden holder that hangs from the shower bracket with a bungee cord and is easily removed when needed.
    It is important to stow or secure it before travel, though. I learned the hard way that the TP likes to unroll itself as you bump along.  :-)
