Waterproof Toilet Paper Holder
JJandJJ
Member Posts: 11
Does anyone know if it's safe to drill a couple of small holes here? I'd like to install a waterproof toilet paper holder? I have a 2017 Max S Comments
Be careful if you choose to do so. Some have had success. Here are a couple of pictures of the construction. Not much more than foam. There seems to be a nice piece of wood on the front driver side wall. Hope this helps.
You can put the TP holder on the opposite wall, next to the kitchen. But no screws. Use Gorilla tape or Waterproof Command Velcro strips.Verna, Columbus, IN
The command Velcro strips didn't work. I'll check out Gorilla tape.
Thanks for the pictures SAM - I'd been looking for something like that
Use a coffee can...
JJandJJ - welcome. It doesn't help that the wood is behind the toilet! As Verna said, you can always try Gorilla Tape/Command strips. We use a TP size Tupperware container left on the floor of the BR and do not worry about anything falling off the walls.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I use a 32 oz Coffee Creamer container with a screw-on lid that has lasted over two years now.Verna, Columbus, IN
The ol' Folgers coffee plastic container works just fine for us. No plans on doing an "open house" of the bathroom area in the near future anyway!
Eric aka: Lone Wolf -
Any clear plastic Costco container of cashews, trail mix, pistachios, almonds, etc. works great - until you realize you left it in the TV. That's when you appreciate the toilet being in the shower.2016 Outback 320
I use a tank TP holder that I hook on the door, then flip it to the outside when I take a shower. $8 maybe, easy squeezy.
Remember to empty the container before trying to put the TP in!Tabaz said:Any clear plastic Costco container of cashews, trail mix, pistachios, almonds, etc. works great - until you realize you left it in the TV. That's when you appreciate the toilet being in the shower.
"Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ. -
Too funny Larry! Perhaps someone just needs to invent waterproof toilet paper. Then we wouldn't need a cover.2016 Outback 320
@Tabaz not sure waterproof TP would be very effective...
I made a simple wooden holder that hangs from the shower bracket with a bungee cord and is easily removed when needed.
It is important to stow or secure it before travel, though. I learned the hard way that the TP likes to unroll itself as you bump along. :-)
- 916 Introductions
- 72 Teardrop Groups & Links
