I added some metal to the two side walls in the kitchen, providing some space to hang kitchen utensils using magnetic hooks. When you go to Home Depot, bring a magnet to make sure you're not purchasing aluminum. I made a template out of paper then drew it on the metal. Using gloves I snipped it out then used a hammer and sandpaper to smooth out the edges and get rid of any sharp edges. I glued it on the way using liquid nails specifically made for indoor/outdoor use. Works great for adding extra storage at a campsite.
Eventually I will paint them using Annie Sloan Chalk Paint (which can paint anything).
aka BirdieJane towed by Quinn
Here is the URL, cost about $60.00 at Home Depot, or you can find them on line. Even though they are peel and stick I used liquid nails. Seems the fire proofing on wall prevents self adhesive things from sticking.
How are the knives attached?
tv 2010 Lexus RX350 Matador red
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
