It worked so well a couple of weeks ago I had to turn it off in the middle of the night because it got so cold in my T@B. I haven't really needed it since but it's gotten very humid here and I'm expecting rain. I've turned on the AC to help cool off the camper inside before the actual rains start. It's just blowing air...not cold or hot. Just air. I've got it cranked up to the max fan and coldest number on the dial. Any ideas what I can try next? It's hot as heck in this trailer right now.
1 ·
Does the filter need to be cleaned?
You mentioned that your A/C was set on "Max Fan." My A/C (a Frigidaire model) has both a "High Fan" and a "High Cool" setting; if you set it on "High Fan" it does exactly as you describe, and the temperature dial has no effect. It must be on a "Cool" setting for the compressor to kick in.
I would also look up inside the pan area, wipe and clean the pan are thoroughly and also check the drain hole and ensure it is clean and that there is no debris clogging the drain tube. If you could find some weed whacker plastic string or something similar you could push it down through the drain hole and beneath the trailer to clear any debris that might be in it and ensure that it's open. Pour some water down through the hole to test it and ensure that it does drain properly.
Mike, I'm about to break camp to go to my next location and will do as you suggest once I get get setup there. Thanks!
Sorry, that's the limit of my A/C knowledge. Never touch the stuff, personally! ;-)
Here is the location of the A/C drip pan drain. It is located directly behind the mirror in the shower. It is accessible by carefully removing the mirror or taking out the A/C unit itself. BTW, this is a standard small window unit that's available for $139 from Amazon with free shipping. I believe Walmart also may carry it.
Is it this one?
http://www.homedepot.com/p/Frigidaire-6-000-BTU-Window-Air-Conditioner-FFRE0633S1/206673498
I believe this is the digital one some have used:
https://www.amazon.com/Frigidaire-Window-Mounted-Mini-Compact-Conditioner-Full-Function/dp/B00IYQY1YI/ref=sr_1_3?ie=UTF8&qid=1462562731&sr=8-3&keywords=mini+compact+air+conditioner&refinements=p_72:2661618011
Same basic unit, but with a thermostat and digital controls. It does stick out of the cabinet a little if I recall from other posts.
For the record, there was nothing wrong with my original one, I just consider this one to be an upgrade.
After reading Mike's comments it seems like I need to remove a trim piece.
Can someone please confirm this?
Also going to call Preston Miller for advice
He always helps
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
