I have the 2016 T@B Norcold with the guts on the left. Compartment will not cool on shore power or propane after 24 hours on each setting. All fuses and breakers are good (including the 3 on top of the unit). Everything else in the trailer works fine on shore power. Green pilot light stays lit on propane. Norcold fan under the coils and auxiliary fans on the sidewall all work on propane or shore power. Any ideas?
0 ·
Just make sure you take off your tinfoil hat when you start telling them all the things you've eliminated (but seriously, make a list of things you've checked so they don't have to repeat stuff).
@RollinWithShirley - the frig is wired for DC and receives power via the converter while on shorepower. Are you sure your converter is working? Turn off the battery while on shorepower and see if you have lights, pump, etc.
Our 2015 three way fridg. Definitely used 120 volt power not 12 volts through the inverter. The fuses in the power panel are 12 volt fuses. I believe the 120 volt fuses are under the stove top. If I remember right there are 2 maybe 3. I think they are 1.5 amps. If you are getting power to the outlet under the sink just plug a light into that outlet. If it works then it’s probably the fuses onset the stove.
Thanks so much for all your help.
https://tab-rv.vanillacommunity.com/discussion/6390/norcold-refrigerator-manual-guidelines-tips#latest
I think the front vents will be a problem. The one on the side is not. I would contact NuCamp and see if they can give you some guidance. The fuses should be available at most hardware store.
i am pretty sure all of the 3 ways are that way.
