Well, it appears that my WFCO 8735 is shot. No 12V power when connected to shore power (batteries disconnected). Of course it is just out of warranty! Grrr...
Volt meter tests show .7 volts at the battery cables and across the fuses, so it seems that it has just given up. Unless I am missing something it seems that a replacement is required. Should I replace it with the same WFCO converter or try the Progressive Dynamics PD4135? Anyone out there have some input or experience with the PD4135?
0 ·
Best of luck to you!
Edited to add: V just said the bad batch were Elixir, and they are out of biz. Still keep us posted!
So far I see no difference between the WFCO and the PD. Output specs appear to be identical so it does not look like there is any advantage to the PD. 6 to one, half dozen to the other, I suppose.
I had repaired mine a couple times but finally replaced it with a new identical unit. Before installation I opened it up and, using hot glue, reinforced the large components attachment to the circuit board so they were not just hanging from their leads. This modified unit has had no problems in over three years of use.
Here are links to some photos of the problem areas from the "*Electrical" photo files @ Yahoo
https://groups.yahoo.com/neo/groups/tabtrailers/photos/albums/561338276/lightbox/1404526128?orderBy=ordinal&sortOrder=asc&photoFilter=ALL#
https://groups.yahoo.com/neo/groups/tabtrailers/photos/albums/561338276/lightbox/859223041?orderBy=ordinal&sortOrder=asc&photoFilter=ALL#
https://groups.yahoo.com/neo/groups/tabtrailers/photos/albums/561338276/lightbox/1415946805?orderBy=mtime&sortOrder=asc&photoFilter=ALL
https://groups.yahoo.com/neo/groups/tabtrailers/photos/albums/561338276/lightbox/886122445?orderBy=mtime&sortOrder=asc&photoFilter=ALL
Appreciate the help!!
I now have 12V power to the camper through the converter but am at a loss to explain exactly why. I suppose all I can do is to keep an eye on it in case it happens again.
The trailer is always plugged in to shore power when home, during the camping season. I disconnect it through the winter, though.
I was led to the trouble spot in my converter by sparks at the broken resistor lead.
OR
If the white wire was the neutral side of the AC supply, it would interrupt the power to the converter. You may want to double check the AC connections inside the converter - circuit breakers, neutral and ground.
Someone once referred to the ride in the trailer as a rolling earthquake. Everything in there really gets shaken during travel.
I would at least rule that out before casting suspicion on the circuit board.
I think @Verna is on to something - I did not think of checking those butt splices! When I get time this week I will check them out.
I have an irreplaceable remote to my gas fireplace (no universals? geesh!). I keep it quietly in one place and it's velcro'd. It resets itself periodically. I wiggle the batteries gently, press the temp limit buttons gently and it comes back to life. Sometimes I just have to get up and take the 3 steps to the fireplace and turn on the switch. The thing is 16 years old! I still like the old thing. The fireplace man said "they don't make this model anymore, but the company still makes a great product!". Nice to know.
Meanwhile, I'm still wiggling and jiggling the remote until it totally dies before I'll invest another $4k in a gas fireplace...
aka BirdieJane towed by Quinn
2011 T@B
Rockingham, NC
My converter was just over a year old so I had to handle the warranty directly through WFCO. 1 year or less needs to be handled through NuCamp, FYI.
Please let us know how the reinstall goes, and share any tips or tricks you discover.
I did take pictures and careful notes when I removed the converter. I was in a hurry to get it in a box and shipped back to WFCO so I really didn't do a good job documenting the process, but just enough to figure out which wires go where. I'm planning the install for this weekend and I will have extra time to hopefully document it. I'll return with details
