Weatherproof Electric Connection
On a recent trip, the only way for me to reach the electric provided at the campsite was to connect an extension cord to the campsite's electric and then connect the other end to the trailer's 30-amp cable using a converter plug. The electric worked fine like this. However, this means that the connection point between the extension cord and the 30-amp cable is laying in the open. How do you protect this connection point from possible weather-related moisture issues? I ended up laying it on a kneeling pad and wrapping the whole thing in a tarp with a brick on top to weight it down. Is there a weatherproof connection cover that anyone could recommend?
Downers Grove, IL
2017 T@B S Max, Blue and Silver -- "The Blueb@rry"
    A gallon Ziplock bag is what I have used at the Campground I am Camp Hosting at. I stuck the connection inside, zipped the bag as far as it would go, added a tie to the bag,  and stuck a twig in the ground to keep the bottom of the bag upright. It worked for that torrential downpour.
    I have to use my 25' 30 amp cord plus a 25' 30 amp extension cord every weekend.
  • FishDoctorFishDoctor Member Posts: 74
    Thanks @Verna. I was thinking a simple solution like that might work fine.
    Downers Grove, IL
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,053
    I have seen that you can take a lidded bucket, cut out an area to fit the cord on both sides of the rim opposite of each other, lay the connection suspended between the 2 cut outs and attach the lid.  Maybe I can find a picture.
    edited September 2017
    Check this out.
    That is a great idea. Could also be a food storage container.
    I think you want to leave the lid off though so no rain gathers inside.
    I like your system @Verna! Simple, lightweight, and compact.
    I'll be discarding my fancy plastic maple syrup jug with the slot cut in.
    Simplify simplify...
    I have had my connections out in the rain without buckets or covers or bags. I just hang the outdoor extension cord down and it's usually partially covered by the battery or propane boxes. There's a waterproof rating on the cord connections (not sure about the adaptors). Qualification - this is when my camper is in the driveway.
    Still good a great idea with the bucket when camping! I have found campgrounds that have electric pedestals where my surge protector and 30A camper plug is on the ground. The bucket lifts them up. I'll need to research this and see if I have something I can sacrifice around the house before buying something.
