HOW to replace kitchen faucet?
Photomom
Member Posts: 2,217
I want to replace the kitchen faucet in our 2016 T@B S. It isn't tall enough to get larger pots or our filter dispenser under, and I've noticed that the black seal between the faucet base and the counter is broken so I'm concerned about water leaking into the cabinet.
If you've replaced your faucet, how do I go about it? Are there any special tools or techniques? Will a standard bar faucet work?
VERY easy to do. There are two holes at 4" on center. This is a standard bar faucet size. Turn off your pump and not be connected to city water before starting. Reach under the sink and unscrew the two water lines from the old faucet (mine were hand-tight, so came off very easily). Then unscrew the two plastic wing nuts holding the faucet to the underside of the cabinet. That's it. Make sure the new faucet spout fits with the front window shade closed.2016 Outback 320
2024 Ford F150 Supercrew short bed.3 -
You want one that has a curved spout to clear the window. A marine unit from Walmart is what I used.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
Does anyone know if the CS T@B uses the same faucet? I have thought about making a change as it is hard to wash any large pots in the sink.Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner0
My existing faucet has one hole - has anyone replaced this type?John and Henrietta, Late 2016 T@B S Max in Western New York0
That's what I had. Marine faucet fits perfect. http://www.scandvik.com/index.cfm/method/Shopping_Products/CatId/121/ID/624.htm or here https://www.walmart.com/ip/Scandvik-70002-Chrome-Plated-Brass-Classic-Swivel-J-Spout-Galley-Mixer-Faucet/332774702020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
My 2016 has the older style 2 hole. There are many single hole kitchen faucets on the market. Measure the raw opening in the countertop and try to find one that fits. Unfortunately, the single hole models may require a larger diameter opening in the countertop. Another option is a single hole bathroom faucet with a taller spout. That's what I did. I used the second hole for a soap dispenser. Good luck!2016 Outback 320
Thanks @Photomom for the picture. That is the same one we have. Thanks @RollingBnB for the answer and links.Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner0
Always wondered why campers don't have standard household fixtures. The original faucet on my T@B leaked constantly and was a nuisance. Since my T@B does not have hot water, I used a single control bar sink faucet. LOVE IT!
Kingston KS8198DL
Here is the Amazon link:
https://www.amazon.com/gp/product/B000F692P8/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Stancil Campbell
2011 T@B
Rockingham, NC
I used the same one that @RollingBnB turned me on to (and love it by the way) on our 2017. But the hoses weren't long enough and I had to get extensions. I would have rather put new pex pipe in, so I could just use the hoses supplied with the facet, but it would require buying specialty tools and parts. It was just easier to extend it.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.1
Are there any faucets that have a pull out spray?0
I am partial to Moen faucets and like the look of this one. It has a pull down spray. I have not measured it out yet, though.
https://www.faucetdirect.com/moen-5995-single-handle-pulldown-spray-bar-faucet-with-reflex-technology-from-the-arbor-collection/p1329134
John and Henrietta, Late 2016 T@B S Max in Western New York0 -
@Photomom measure the height where the faucet will sit to make sure it will clear the window.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az2 -
I bought a brushed nickel Moen bathroom faucet (it was on sale) with a 4" spread for my 2015 T@Bitha. It originally had the dual handles and the faucet that wasn't positioned correctly and sprayed water everywhere except in the sink.
The bathroom faucet I bought was perfect (height and bend). One thing I ran into was the holes weren't perfectly 4" apart. I needed 2mm more room on each side for a perfect fit. It wasn't hard to do with a scraper or good file (tape the counter with painter's tape!!). Empty the cabinet underneath. Easier to clean the filings! Still only a 30 min job, even with the filing. Worth it!!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2 -
2022 Tab 320 CS-S Boondock0
- 144 Events & News
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
