Elsie has available the vinyl cover for the Cool Cat heat pump.   We ordered it with 4 extra male snap connectors that mount on the screen.  you Install the snaps to the screen and we  added 4 extra female snaps to the cover.  It is available in Gray or White color.  I also added 2,1 inch wide straps sewn to the cover on the back top to come around the cover. When it is reverse rolled up it snaps into two male snaps We added to the cover.  That way you just unsnap the sides and bottom, roll it up to the top and then snap it in the up position.  When we travel, we lower it and snap it in place.  I keep it down when stored to prevent wasp and other insects from nesting inside the a/c.
While I was placing the order, I also ordered the Battery back up for the Alde thermostat. Skwee told us about that early on when ours 400 was in progress. It allows you to turn your battery cut off switch off and you will not loose the clock settings on your Alde thermostat. The part# is 66-00-4831. The price for the back up is $9.20. This is an optional part and you may or may not have a need for it. We keep our 400 on a battery tender when at home and rarely use the battery cut off.
As you use your new 400 you will find little things that you will add or change to suit your style. This is part of the unique T@B owners experience. We have done several other little things to change ours and you will definitely enjoy such a great product as the T@B.
If I can help with other answers feel free to ask.
Fred, Donna and Jaxson
Concerning our our solar panels, we haven't used them yet so I can't say anything about that. Our 400 came with them and the converter already installed. I will let you know if and when we use solar.
2013 Tundra TRD 5.7L
Massachusetts
Moving down the road, most road spray is going to slip stream right by the grate and any debris of any size is going to be stopped by the grate. In addition the factory cover has some flap to it going down the road. Just don't see the point.
Massachusetts
And this one: https://tab-rv.vanillacommunity.com/discussion/12361/outside-cover-for-coolcat-ac-vent-t-b400/p1
