I am a RV newbie who asks newbie type questions. We purchased a T@B 320S from Nucamp. It has an Autowbrake electric brake controller and a 7 pin trailer connection. Our tow vehicle is a Subaru Outback 2015 with a 4 pin connection. The T@B dealer supplied us with a 7-to-4 pin adapter. All appears to be properly wired (all the trailer lights work) but I cannot tell whether I have trailer brakes when towing. Question - assuming everything is set up correctly, do i have trailer brakes?
0 ·
2017 T@b 320 S
2017 Kia Sorento SXL AWD
In order for that extra stuff to work, you would need to have a properly wired 7-pin connector on your Subaru.
can get at Walmart just to confirm a working 7 pin.
https://autowbrake.com/
I wonder how/why the Autowbrake came to be installed on this particular T@B. I'm pretty sure that's not standard equipment.
I wondered if maybe the dealer just took the liberty of installing the Autowbrake when they saw what you were planning to tow with. It would certainly be worth asking.
You drive 10-15 mph then press the fob button. You should notice the trailer tugging on the TV as the brakes engage.
See last paragraph here: https://autowbrake.com/p/autowbrake-installation
I'm still curious as to who installed the Autowbrake on your trailer, and why.
I am really struggling to find someone to rewire our new Ford Edge from 4 pin to 7 pin. I thought I did enough research in advance and now I am in a panic.
No, Uhaul won’t do it. One RV place in town wants over $300. Is that normal? Anyone know a reputable trailer place in St. Louis? I found one on google in zip 63103 with no website, no phone and the pic is a high fenced lot. Um no. I just don’t know where to turn and goodness knows we are not handy. I feel like I am going to
I see @Dalehelman you say it should be fairly simple. The Apache dealer said the vehicle would have to be rewired and something about running a wire to the battery of the Ford, something, something, OEM, something. I blacked out after he quoted two hours at $135 an hour plus parts.
I don’t even really know the language I need to use to ask for what I need. I tell them “I have a 4 pin but I need a 7 pin and an adaptor isn’t enough because I have trailer brakes.” What else can I say to explain it? Any ideas? How am I going to know if they are ripping me off? Is there a kit I should buy and deliver to someone to do it? Will they get a better price somewhere? Is there a more reputable brand I should get? Is there a chance they are going to screw up all of my wiring?
Ugh. I am literally in tears right now. Any help would be appreciated. Thank you.
http://www.rockroadtrailer.com/
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
Assumption One . . . 'convert 4-Pin' means Edge has Factory Tow Package with 4-Pin installed.
Assumption Two . . . Need 4-pin to 7-pin, Need +12V for T@B, Need Electric Brake Controller
Possible Solution:
For Electric Brake Controller purchase a wireless system to eliminate extra TV wiring issues or costs. For example the Prodigy RF Wireless Trailer Brake Controller.
For 4-pin to 7-pin. Since TV already has a 4-pin any* universal 'wired' adapter will work. *of course with correct blade style 7-pin.
For +12V to T@B from TV. On the Edge a wire must be run from battery to 7-pin connector. Wire should be large diameter, 10 AWG is typical. Wire from battery to 7-pin must have an in-line Fuse to protect the TV electrical system if there is a failure on the T@B side.
As others have said 2-hours sounds like a reasonable quote. Finding a non-RV Dealer shop should lower the hourly rate some.
