Hello T@bbers! I have taken the plunge and ordered a new Tab Sofitel Q Maxx with Alde, front window and outside shower. I'm told they will be building it in early March. I can add options if I order them through my dealer very soon. I'm thinking about asking for factory bedrails, a 112 electrical outlet inside the front cabinets (for a small microwave I have) and possibly an electric outlet in the back bed area (for when the back bench is down).
  Not sure yet how to go on the back outlet. One thought is to see if I can get a 112 V outlet put in the center of the back shelf where the superflous finger hole is (you can't open the shelf as it's sealed due to Alde innards taking up that space). But then the 112 V would only work when hooked to "shore power". As I'm thinking that the greatest use of a back outlet would be for charging phones, tablets and other small toys, I might be better off with a USB type outlet that would charge off either 112 or 12 V. It looks like power for that type of outlet might be tapped off of the back cabinet mounted lights. Not sure how accessible those are behind the cabinets for DIY modification. And would it be better to have it down by/on the back shelf anyway?
  So, looking for thoughts on these potential mods, as well as my general topic; what factory additions would you most like on your T@b?  (or which one's do you have that you like best?)  Thanks all!
                0 ·
I would also like to see the option of a hard wired surge suppressor for the 30 amp shore power and a house battery switch inside to disconnect the trailer from the battery while stored.
Tank monitors and a volt meter would also be nice to have.
Would also like the option of a high efficiency electric only fridge. Possibly an option for an induction burner inset into the counter in place of the propane stove top.
I do wish the fake stainless behind our stove and sink would work with my magnetic items. How about surfaces that would allow us to use suction cup holders?' I had big plans for lightweight storage and organization
love using suction cup holders in a bath when traveling.
This would allow folks to put their coats, purses and other gear off the bed and floor since there isn't a closet in the T@B M@XX.
Photomom - I'd still start there, make an assessment and press them to find out if you feel they're not up on what can or can't be. From what I understand though, almost anything is changeable, all depends on how much you want to spend.
Not all dealers are the same. John Gerton at Gerton Auto sales and Haydocy are two of the great ones. They became great because they asked the questions of the factory and they learned.
Since just about anything is customizable, make a list of the config/options you want... Front trim blue, back trim red, sidewalls white with pink polka dots, outback axel, outdoor shower, Orb freezer instead of fridge, etc ...then sit down with a dealer and have them price it out for you. It may be expensive and take a year but almost anything is possible.
Can't recall, have you been to a dealer with a wide selection of models so you can see what the standard options are and what may be easy to mix-match?
We are both engineers and my husband also holds an MBA. We must have all our ducks in a row before making a decision, that's just the way we roll. When I buy a car or really anything else I research everything down to the last detail in advance. The nebulosity of "anything is customizable" without knowing what all the "anythings" are just doesn't sit well!
Glad to hear you found a dealer you feel you can work with. For some reason I was under the impression you hadn't found a dealer at all yet so that's good news :-)
Betting there are so many variations it'd take a library of vids and then nobody'd be able to figure out which applied to them. More mass confusion :-)
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota
