Alde Circ Pump Setting?
In trouble-shooting my lack of heating on propane (HW works OK), I’ve hooked up the T@B to shore power to see if it’s the glycol circulating pump.  After 30 minutes it seems to be working and circulating fine.  However, I did notice the “red knob” on the circ pump is set at its lowest setting (1)...is that standard?  Why not set it higher for faster heating?
J.D. & Sue
    @DurangoTaB, if this is the same thing, I have the circulating pump set for 2 in the digital Alde thermostat.
    @Verna... it’s the small “knob” on the pump itself (we have the analog thermostat).  I’ve turned the knob to “2” and it’s heating up slowly.  I’d forgotten how much slower heating is with electric (I’m on a home/15A circuit) vs. propane.
    J.D. & Sue
    @DurangoTaB, If I remember correctly "2" is the factory setting for the dial on the pump (if you're referring to the red dial on the pump next to the floor by the Alde hot water reservoir). Not sure how it got turned to one. You're right in that it takes longer when using electric only. You can speed it up a little if you use propane as well. That being said, I'm pretty sure I read in the Alde manual that electric takes presidence over propane.
    @Verna, curiosity question: Have you actually heard the pump increase in speed if you try to turn the digital Alde  setting up higher than 2? The only time I've been able to increase (and hear it increase) the pump speed is by manually turning the dial on the pump itself.
    @ericnliz, I set the pump at 2 when I replaced the thermostat and I haven’t changed it. I can hear the pump kick on when first connecting, but it has been sufficent so I haven’t experimented. If it’s not broke, it’s staying as is ;)
  • Sharon_is_SAMSharon_is_SAM Member Posts: 10,066
    So, we visited nuCamp today and had the high altitude propane regulator placed and a leak repaired in the new license plate holder.  I was cleaning, and while under the bench, I took a look at the Alde circulation pump manual setting which was set at 1 and I realized that we had set the circulation pump at 2 on the digital control panel.  I asked Austin and he reported that if you have a pump that has the manual setting, that is what you use to set the pump speed.  He said in this scenario, the digital control panel does not adjust the pump speed!  It does not include this info anywhere in the Alde or TaB manual.  He said that early on they received some pumps without the manual setting and the pump speed can be controlled with the digital control panel.  So, who has the pump without the manual setting and has upgraded to the digital control panel?  Verna?  Chan?  Mike?
    @SAM, remind me Saturday and I’ll look. Very busy week!
    OK.  I just think it is funny that we have been using that feature on the control panel thinking that we were actually doing something.  Our pump is silent and no wonder, it is running at the lowest setting.
  • Tabaz Tabaz Member Posts: 2,414
    I am VERY sensitive to noise. I have my manual red knob set about 1.5. Anything higher becomes an annoyance.  This setting has worked fine for two years in the Southwest (I.e. The Alde puts out plenty of heat at the lower pump setting).
    Tabaz - yes, we are fine with our current setting.  Austin said that the higher circ settings are for larger RVs and not really necessary for the TaBs.  I also wonder if CS owners hear less noice because the reservoir is behind the hatch in the bathroom.  Do you have the digital display?
  • BrianZBrianZ Member Posts: 1,768
    Can someone please post a photo of what the Alde pump with a dial looks like & showing where it's located?
    edited October 2022
    Similar discussion here...see RollingLagrima’s pic of the pump; it’s a little hard to see the red “dial” as it’s down near the floor and sideways:
    https://tab-rv.vanillacommunity.com/discussion/5716/alde-troubles
    J.D. & Sue
    OK Verna.  When you can, check your Alde pump.  Do you have the pump without the manual setting and the digital Alde display?  If so, you are the lucky winner to have a digital display that should control the pump!
    At half time I will....IU at Michigan......I’m not talking to Michigan_Mike right now!
    Go Hoosiers!
    Oh, my! An Admin & moderator college basketball battle! :rofl: Go ZAGS!!!! They won last night by the way!!!! =)
    < Clearing throat  >.  Ahhh, two Admins, @ericnliz!
    Excuse the need to vacuum.....it appears I have no settings on the pump.  So, my digital thermostat does nothing for the pump, right?
    Winner!  Verna, according to Austin, the pumps without the manual adjustment tab are controlled via the digital display.  Try it some time and let us know.  Turn it up to 5 and listen and then turn down and see if the bubbling does not reduce.
    OK, I”’ll try it this week. Time to be packing  B)
    edited December 2017
    Found our pump, with a little help from my cell phone camera to "see" into a blind corner.
    Looks like ours is set to "1", but this was perfectly adequate on a couple of nights in the upper 30's, just by keeping the thermostat set to around 68 to 70.  We've been very impressed with the Alde's ability to keep us warm.   It sure beats the Army days I remember sleeping on the cold hard ground with nothing but a sleeping bag & waking up to everything covered by frost.
    Hey @SAM, I’m winterized, so I won’t be able to try it for a while. I’ll try it when de-winterized.
    BrianZ, yes, 1 is fine as the Tabs have small radiator runs.  Do you have a 320?  I wonder if the 400 has the same manually set pump?
    Oooops! Sorry @Verna. :s
    ( Must not have had enough :coffee:, I REALLY do know better! :))
    OK Verna.  Are you going to work in a cold trailer?
    No, the Alde will have to be on this week with the forecast.  So, this is the circulation pump for the glycol?  Then, I’ll try this week.
    Yes, Verna.  I want to see if using your digital display changes your pump speed and is it audible.  Thanks!
  • AMacAMac Member Posts: 75
    Our 400 does have the manual setting.
    AMac - what # setting is it on?
    @SAM, the display only allows me to change from 1 to 2 or back to 1.  My hearing isn’t the best and I sure couldn’t tell any difference in the sound of the pump with the seat off.
