On Our First Trip With Our 400
Big Grover, the pressure relief can drain the cold and there is also another valve in that same line. can use that also. I try not to use the pressure relief valve as a drain too often I kinda look at it like one on a hot water heater at home. Sometimes using the one at home if not used much will start to leak and need to be replaced. The valve in the line should drain the same as far as I know.2018 T@B 400, 2017 Nissan Titan Crew cab0
Thank, emailed you some pics.BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama0 -
Set up, ready for a Scotch Whisky now!BigGrover
Central Alabama0 -
BigGrover
Central Alabama4 -
Perhaps no one told you, but posts from campsites must include at least one photo!BigGrover said:Set up, ready for a Scotch Whisky now!
Gail & John
See post below, don't know why pic didn't ho thru The first timeBigGrover
Central Alabama0 -
lol ignore funky tv antenna pole and glasd of Ardbeg 10 on table BigGrover
Central Alabama0 -
Ignore? It is perfect! Painter's poles are the perfect camping all around accessory. (If that is what it is...)
Towed by 2014 Touareg TDi1 -
It is a pool skimmer pole. Jury rigged for mow. Gonna fix the pvc to the jack permanently as a base when I get home.BigGrover
Central Alabama4 -
You've got 3 different threads going on this. This one must have been post-whiskey! Enjoy!BigGrover said:See post below, don't know why pic didn't ho thru The first time
Gail & John
@BigGrover, we use a safety yellow painters pole attached to the front handle with a ball bungie. Sometimes the simplest thing is the best.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0 -
The whisky must have been good as you started two of the same threads.
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1 -
Michigan Mike, it was good and, since it was scotch you spelled whisky correctly. I did the posts before imbibing though. The 4g here is spotty and the picture didn't upload with the first and the second post went twiceBigGrover
Central Alabama1 -
@BigGrover Here's a thread about a painter's pole AND cell power! @jkjenn, @Verna and @Tabaz have solutions! http://tab-rv.vanillaforums.com/discussion/5161/weboost-drive-4g-s-cell-phone-signal-boost-for-a-single-cell-phoneJohn, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner1 -
Looking Good Big Grover! Enjoy! Our local campgrounds to open soon after Mar 1st. Hope to catch a couple days and get out!
2018 T@B 400, 2017 Nissan Titan Crew cab0 -
@BigGrover, what you have there is your first mod, with many more to come! That’s the beauty of owning a Tab, you get to personalize it to your hearts content. Thanks for the pic!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
