On Our First Trip With Our 400
2»
  • atlasb
    atlasb Member Posts: 584
    Big Grover,  the pressure relief can drain the cold and there is also another valve in that same line.  can use that also.  I try not to use the pressure relief valve as a drain too often I kinda look at it like one on a hot water heater at home.  Sometimes using the one at home if not used much will start to leak and need to be replaced.  The valve in the line should drain the same as far as I know.
  • BigGrover
    BigGrover Member Posts: 450
    Thank, emailed you some pics.
    BigGrover
    2019 T@b 400 Boondock Lite
    2018 Ram 1500 Quad Cab Hemi
    Central Alabama
  • BigGrover
    Set up, ready for a Scotch Whisky now!
    BigGrover
    Central Alabama
  • BigGrover
    BigGrover
    Central Alabama
  • GailandJohn
    GailandJohn Member Posts: 123
    Perhaps no one told you, but posts from campsites must include at least one photo! ;)
    Gail & John
  • BigGrover
    See post below, don't know why pic didn't ho thru The first time
    BigGrover
    Central Alabama
  • BigGrover
    lol ignore funky tv antenna pole and glasd of Ardbeg 10 on table
    BigGrover
    Central Alabama
    pthomas745 Administrator, Moderator Posts: 4,684
    Ignore?  It is perfect!  Painter's poles are the perfect camping all around accessory.  (If that is what it is...)
  • BigGrover
    It is a pool skimmer pole.  Jury rigged for mow.  Gonna fix the pvc to the jack permanently as a base when I get home.
    BigGrover
    Central Alabama
  • GailandJohn
    You've got 3 different threads going on this. This one must have been post-whiskey! Enjoy! :)
    Gail & John
  • dragonsdofly
    @BigGrover, we use a safety yellow painters pole attached to the front handle with a ball bungie. Sometimes the simplest thing is the best.
  • Michigan_Mike
    The whisky must have been good as you started two of the same threads.  :o=)
  • BigGrover
    Michigan Mike, it was good and, since it was scotch you spelled whisky correctly.  I did the posts before imbibing though.  The 4g here is spotty and the picture didn't upload with the first and the second post went twice
    BigGrover
    Central Alabama
  • jgram2
    jgram2 Member Posts: 1,522
    edited February 2018
  • atlasb
    Looking Good Big Grover!  Enjoy!  Our local campgrounds to open soon after Mar 1st.  Hope to catch a couple days and get out!
  • Homebodyatheart
    @BigGrover, what you have there is your first mod, with many more to come! That’s the beauty of owning a Tab, you get to personalize it to your hearts content. Thanks for the pic!
