). In the meantime I've learned to crank it up hotter than I need it then turn it down when I'm warm enough as I tend to run cold a lot. I also close up the windows late afternoon, holding some heat from the day in. I turn the heat up later. I've also (knock on wood!) never blown a fuse yet. I am meticulous about the order I plug in and turn things on and off. Some day one will blow, and I have spares. Anyway, keep asking questions and search for past answers on the forum. The archives and people here are a wealth of knowledge! Enjoy the journey! Being a year and a half into this, the up side is that the T@B as a whole and the Alde are remarkably well conceived, designed and made products. The towing characteristics, breaks, suspension and bearing systems seem to be of the highest quality and well integrated. The 3 way refrigerator and Alde have performed well.
But there is a major down side.
This is a very complex system, and the learning curve is substantial.
Documentation is not well unified and difficult to sort out. We got a huge stack of manuals, but no real plan on how to work with it, and although the material was there it is buried in among an enormous amount of verbiage that is irrelevant.
The essential problem is that this is a small and diverse market. In autos or trucks 95 percent of the market is in a hand full of brands with relatively strong dealer networks, documentation and parts supplies. The average trailer owner may be hundreds of miles rather than tens of miles from a dealer. And each dealer serves many brands. And, for instance, a 2011 Chevy Silverado is a known quantity with documented circuit diagrams and functions. Travel trailers are essentially built one at a time, and are undocumented except for what is put together by the internet community.
The plus side for the T@B is that factory support for the trailer and its components has in my experience been very good.
The major down side has been our dealer experience:
T@B Dealer Experience, General RV in Huntley, Illinois
We have been quite satisfied with our T@B trailer and although there is a steep learning curve there have been no issues of construction, quality or reliability. The dealer experience, however, is another story.
Our dealer was General RV, in Huntley, Illinois. This is a big chain with a lot of stock and an elaborate sales program, but very poor service. To understand why, you need look no further then their web site, where you will see the notice: "We need RV technicians, and no experience is needed!"
When we made the purchase we were absolute beginners. We were told that we needed a break controller, so we got suckered in and paid $120 for a unit available on Amazon for about $60 and something like $120 for installation.
Tow vehicle is a 2011 Chevy Silverado half ton pickup.
"Installation," took all of five minutes, consisted of ramming two screws into the dash board and mounting the unit so that you could not see the LED indicators, or easily reach the controls. They hooked up the two under the hood wires for the controller and the trailer 12 volt power feed but just hand tightened the nuts, you could literally move them with your fingers. Naturally the brakes were intermittent, and it took some serious time and frustration to trace down the problem, including an hour or so with the manufacturer technical guy. (Tekonsha – Primus Factory support was excellent.)
They also hooked up the under the hood 12 volt trailer power lead, but did not plug in a fuse or inform us that we needed to do it. The first couple of test runs went fine, in retrospect we were on shore power prior to going, and plugged in to 120 volt on arrival; we thought we had 12 volt in transit but did not.
On our first extended trip the battery was dead about six hours out. I was able to figure out what the problem was relatively quickly, but finding the little square, green 40 amp fuse on the road is difficult; the local Chevy dealer parts department could not find it in stock, but then the counter guy dug out two of them in a box taken from old equipment and gave them to us free.
Then the interesting part, the thing had power on, but was still not charging very much. Digging through the inch and a half thick Silverado manual, we found deep in the small print the fact that the trailer power would not charge a battery unless the truck transmission was in tow mode. Who would have thought that the power feed charging enable was by means of the automatic transmission control?
I don't know about other dealers, but my conclusion is that to do this you pretty much have to commit to being your own mechanic, and really research anything you have to go to a shop for. Part of the problem is that there are so many trailer brands out there, and that apparently model year does not mean all that much, changes seem to be put in at any time as production goes on. But General RV is really dedicated to poor or outright abusive service practices, and it comes from the top down to those service technicians hired with no experience, presumably because they are willing to work for less.
factor, come here & ask!!! I do!!!!!!
Get out there & have fun....after all, that's what you bought your T@B for...right?
pthomas745 makes an excellent point, but there are practical difficulties.
As an example, there are lots of bike shops across the country, so it is relatively simple to find local shops and then figure out which guys are reliable and fair. I got so confident in our local bike shop that I bought my last bike without even asking the price, had that much confidence. He kept spare not available parts such as the sprocket gears and bearing retainers from discarded assemblies and would give you what you needed for free in a pinch.
The problem is with much less density how do these self taught craftsmen and people needing help link up?
How many people in the Chicago area, for instance, need help with an Alde this week?
Is there some way that we could use the internet, this forum for instance, to set up some sort of reference mechanism?
J.D. & Sue
I loved that book. Just have recently read it again.DurangoTaB said:Many of us T@B owners are first time RV folk, and we mistakenly think when we pay a premium (T@B, Airstream, RoadTrek, etc.) we also should be getting excellent service and support from the dealer. Not always true. I paid a premium for my Tacoma for that reason. But hey, my neighbor has an $85K Airstream and he’s had more problems than I’ve had! RV’s are different...Having done my share of boating/sailing I am often reminded of “Zen and the Art of Motorcycle Maintenance”...you know and take care of the bike and it’ll take care of you. NuCamp does a darn good job considering their challenges, and this Forum is a wealth of information and helpful people, 24x7 no less!
New 400 owner hear browsing the list to try to fix all my problems. Good to hear that most folks are happy with the Alde, we've found it a real bummer moving to this from the forced air heater of our Hallmark Pop-up (you jump in and are warm in 4 min). It takes many hours to heat up, hot water runs out really quickly (and we have to really fiddle to get it hot enough), and now I seem to have a problem that others don't have... we get 'gas failure' and the alde stops even though there is propane. I kinda think this is due to low voltage after a few different tests, but it happened after only 2 nights of pretty conservative use (and with a solar panel). The Alde service folks are nice, but they don't seem to have a way of diagnosing whether the unit is actually working right and now I'm going to have to find time to take it hours to a dealer to hope that things can get fixed. Oh, we have a glycol leak too around the fill tank.
Anyone else have a 'gas failure' or glycol leak issue?
Thanks!
, but on one of our first trips I took advantage of that wonderful luxury, thrilled with the fact that our little bed-on-wheels had such a thing!
