Need AGM suggestions
phulishcat
Member Posts: 89
looking to replace our wet batteries with AGM for our solar system. Need at least 250ah and dual 6v. If you have batteries that you love let me know. Thank you in advance.
We are using Vmax Charge Tanks, 225 AH GC2. Has worked out well.
John2007 T@B
Rockford, IL
Hey Martin, i'm also using a Vmax charges tank. SLR 155 .Very happy with it .
Barbara2015 CS. Ford f150 v8. Southern california -
The nice thing about this battery is that it fits in a standard tub without messing around. A little less power, but batter than the stock battery.
https://www.amazon.com/dp/B00DDYM1UC/?coliid=I2AJFMNQRYB0JC&colid=SNS4MFMP6VLR&psc=0&ref_=lv_ov_lig_dp_it
Mickey & Terri
2016 Max S
Kalamazoo Michigan -
Did you find a battery box for the SLR-155? would like to keep wiring covered.
2022 T@B 320S Boondock -
Does anyone have any idea how that SLR-155 does with all the vibration of an outback? I spend a bit of time on rutted gravel roads and worry about how that might reduce the lifespan of the battery.T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
(previous 2018, T@B 320 Outback) -
I have two VMaxTank 6V agm batteries stacked in my standard 320 tub, and have been using them for almost 2 years- very happily. I've comfortably boondocked without solar supplement for 4 nights... and with some careful conservation, could likely go a week. This is just short of a full screaming endorsement because I just had an unexplained low voltage moment and I'm not yet sure if it was old man user error or a battery problem. I've got a two night boondock trip next week, and a four night boondock trip the following week... so will know soon. Note that a 225 amp hour battery setup takes quite a while to recharge... like, depending on state of charge and charger, 18 hours. I've happily used a NOCO Genius 10 as primary charger/ maintainer.
Yanni Lazarus 2020 T@B320S, 2018 RAV4 Adventure, Central CT -
Two Vmaxtanks VMAXSLR125 AGM's have worked well for us.
I use two, 6V Vmax, 235AH AGM batteries in my 2021 320S. I just camped for three days in northern, lower Michigan. I used my refrigerator the entire time, lights, television, water pump (showers & dishes), and heat. I would get down to about 88% capacity overnight. Because we had good sun, my suitcase and factory solar panels had me back up to 100% by early afternoon all three days. I'm really happy with my choice!
- 917 Introductions
- 73 Teardrop Groups & Links
