Hi, Brand new owners of a T@B 400. We'll be picking it up sometime within the next week or two. So exciting! But to my question...we're first time travel trailer owners of any kind. We thought having the sway bar installed might give us peace of mind, since we are absolute newbies at this. If we don't mind spending the money on that, is there any reason not to do it? Thanks in advance. Looking forward to learning lots from this group. We will be towing with a Nissan Pathfinder.
Karen and Bill
St. Joseph, MN
2016 Nissan Pathfinder, 2018 T@B400
0 ·
IMHO If you’re trailer is loaded properly ie tongue 15%-20% of total weight not to exceed TV or trailer specifications neither of those things are needed. I would but my money to better use.
Short answer is No, there is no real negative to having a sway bar installed. Depending on the type/style of sway bar installed you might have the extra task of disconnecting it before backing up.
Most T@Bbers** don't seem to use sway bars, while many folks do for the same reason you are considering; Peace of Mind, a little extra safety factor.
I'm also a new T@B owner (have towed boat trailers in the past) and I'm going to use the frequently suggested approach to first do some actual towing*** and see how everything goes/feels before adding something like a sway bar. Adding a sway bar is not a big deal task.
Use the forum SEARCH field (upper right, below username) and search for threads with talking about your tow vehicle T@B combination.
Adventures: 58 Nights: 405 Towing Miles 50,180
We tow with an Xterra, and had a bit of sway, so I installed a cheap friction sway bar. Later , I moved the spare to the tongue, and added a battery. That took care of the sway.
Dealers want to sell you a much as they can while they've got your attention. Wait and make an informed decision. My .03 cents.
2022 Ford F350 Tremor | 2022 Cirrus 620
Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado
I tow most of the time with an Equal-i-zer 6K hitch (overkill) but it has seen me perfectly through some dangerous situations, plus I can back up without removing it. My T@B 320 tows okay without it but it's much more stable with. I also have a Weigh-Safe hitch (overkill) to make it much easier to check the hitch weight. It seems to work well and is made with high quality materials but is noisy when towing. I tend to go with overkill (ex. my preferred TV is a V8 Grand Cherokee Overland) because as a retired engineer I prefer safe configurations to mangled bodies and explanations. The owner's manual of my 2015 Grand Cherokee Overland does not mention sway bars, only the vehicle's Trailer Sway Control (TSC) capabilities.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Alan
2018 T@B 400 Jeep GC
Alan & Joan Fisher
Austin, TX
Karen and Bill,
Landed in Austin for a few days from our FLA trip and now we are off to Tuscon. Thought that I should give you an update on my sway bar thoughts. I earlier said that we felt no reason to add a sway bar to our 400, but I now think that it might be a good idea to have one.
Through NM we got into some high wind advisory mountain canyons. I had put our sway bar on and felt much safer. The Jeep GC and 400 acted as one unit. I had not realized that on our earlier trip, without the sway bar I was instinctively correcting to prevent the 400 from swaying when big trucks passed. The sway bar does make groaning noises when you stop for gas and are making tighter turns, but no problem. After we left the interstates, I made sure to remove the sway bar, but it was a wonderful comfort on our trip west.
if you do decide to add a sway bar, you need nothing more elaborate than a simple Pro Series or Curt bar...around $ 40.00
Here's the hitch system that I purchased...
https://www.etrailer.com/Accessories-and-Parts/Curt/C17128.html
https://www.etrailer.com/Accessories-and-Parts/TorkLift/TLM9005.html
Make sure you get a side ball mount that is welded to the hitch adapter. No add-on mounts!
Installation video for the sway bar makes DIY look easy. Purchase a few good drill bits and get started...However, I found drilling into a trailer tongue was more than I wanted to handle. After an hour I had hardly make a dent in the trailer frame. Finally I took the trailer to my RV dealer and gave them a hundred dollars to install the sway bar plate for me. Also, ask them to add the 1 1/4 ball for the sway bar at the proper torque.
Hope all this helps,
Alan, Joan & Willie
Alan & Joan Fisher
Austin, TX
We just came through southwestern Arizona today with high wind advisories, sustained winds at 60mph and dust storms. They even considered closing I-10 if the wind got worse. Big box rigs were parked in rest stops because of the wind. But, our V6 JeepGC and Willie our 400 with its sway bar cranked up tight worked like a team and we had no problems. We were so thankful we had the sway bar.
In our opinion, even if the sway bar stays stored during good weather, it's so beneficial to have one ready to install if you need it. T@Bs pull wonderfully, but trailers are trailers and they all may sway in high winds.
Alan, Joan and Willie
Alan & Joan Fisher
Austin, TX
St. Joseph, MN
