When I was shopping for T@Gs, I noticed the dealer was using the same key for all the trailers he was showing. He mentioned that's how they all come from the factory and you have to order custom locks to have a unique key. Does the same hold true for the T@Bs? I'm assuming it's the same lock model that NuCamp uses regardless of T@B or T@G.
I saw Verna's remote lock post and wondered if I might as well throw it on the upgrade list. I know it's not likely a fellow owner would be poking about in someone's trailer. I'm more concerned about RVs in general and if there are only a few model locks in use on the market. Kind of a peace of mind thing I guess.
0 ·
https://www.google.com/search?q=tab+keys+the+same+site:tab-rv.vanillaforums.com&oq=tab+keys+the+same+site:tab-rv.vanillaforums.com&gs_l=psy-ab.12...0.0.0.13880.0.0.0.0.0.0.0.0..0.0....0...1..64.psy-ab..0.0.0....0.WcbyhrcKusw
2011 T@B
Rockingham, NC
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Just confirmed that many manufacturers will order the same keyed lock for their trailers so they don't have to mess with hundreds of different keys. I just ordered a 900 series replacement lock for my Outback from rvlocksandmore.com. Best to call in your order if you want extra keys shipped with it. Very nice people.
http://www.rvlocksandmore.com/LocksKeys/Security-Upgrades/TTL-43900-2006
http://www.rvlocksandmore.com/LocksKeys/Security-Upgrades/CLB-Cam-Lock-Barrel
Common RV door and hatch locks are manufactured in bulk and allow use of a master key by model or series key code. The master key opens any lock of the same model while a series master key works on any lock of the same series.
You are not going to prevent a determined thief from breaking into your trailer by changing the door lock. However, a uniquely keyed lock will prevent "opportunity theft" where an unscrupulous person with a master key walks up to your unoccupied trailer and lets themselves in. That could happen in broad daylight without anyone noticing. <sigh>
RVLock states "This is a Non-Mastered Key Code Series That is Not Accessible With Any Master Key."
That means serialized keys whether you opt for their 900 series exact replacement model ($35) or a high-end model with fob and keypad ($$$). You'll need the 3 digit number engraved on the series key and proof of prior purchase to obtain replacement keys.
They also offer a Mechanical Entry Door Handle ($29.99) at RVlock.com which lists on Amazon. This model has slightly larger "ergonomic" finger pull indent. However, the interior door side of this lock is sturdy plastic, not metal.
The Security Series Entrance Lock ($35) is a direct replacement, 98% metal, and comes in white, black, or chrome. It is only available at RVlocksandmore.com.
I ordered an RVlock Mechanical on Amazon before I knew the differences and decided to keep it. Metal sounds better though.
I don't know what portion of the premium models are plastic.
It is unclear what brand/model lock is on the T@B 400, but it looks more substantial than the common RV door lock on our 2015 T@B 320.
I rode the motorcycle to an event and then couldn't start it to leave. Wha? Do'h, the bike I have has a keyless system. Just carry the fob. Why yes, I had two batteries for the fob (which needed two)! I impressed the dewds. There's a manual way, but it was easier to change the batteries. hehe.
The throw(?) of a common household deadbolt is probably is too wide (thick) for the narrow door frame.
2016 Toyota Venza 3.5V6
2012 ShihPoo White
