winter. A likely cause is the thermocouple and it looks like I can get my hand in there where the thermocouple enters the burner assembly (see photo). Does anyone know it the thermocouple just pulls straight out? Is it feasible to do this without removing the fridge? Has anyone done this?
https://www.harborfreight.com/7-piece-3-8-eighth-inch-crowfoot-sae-wrench-set-94426.html
Agree parts drawing does not show any type of retainer part so it's logical that the thermocouple pushes into place.
Why are you so sure the thermocouple has failed. What tests have you done. Can you see/hear the pilot light? Can you confirm the flame goes out when the 'push knob in' for extra gas flow is stopped well after the thermocouple should have heated?
Do you have copy of the 3163 Service Manual ?
I found on on-line.
It shows a 1-Amp Fuse in the Propane Gas Control circuit.
Would definitely check that fuse.
The Service Manual troubleshooting flowchart also has Thermocouple Failure near the end . . . lots of other possible causes before that.
https://www.manualslib.com/download/737837/Norcold-3163.html
Best of luck to you.
The word you’re looking for is “bimetallic.”
There is a double housing. I managed to get the first housing off of it doing T@B yoga thru the sink panel. I have a bunch of magnetic tools and bendy ones.... imagine my vocabulary when MY frig had another housing over it and there was no way i could get to it. This doesn't mean your frig is the same. I had an early 2015 T@Bitha. My issue at the time was simple and thanks to this forum, I then knew to level everything.
The next issue was the grommet has a glass window in it. When I went to examine where the thermocouple existed, the grommet was NOT in it's designated spot. Geesh. Don't let it escape its hole!! I couldn't count the number of bruises on my arms and the body contortions and TIME it took to get it back in that itty bitty tiny hole. I did it though. My vocabulary went beyond sailor-ish by the time I was done. I think it was nearly 2 am. I used every trick to get a grommet in (special grease on one side, angle it went in, prayer, ancient rituals). I was considering a sacrifice at one point, but then I realized I'd already sacrificed a few back muscles. It finally popped in - sigh of relief.
Don't touch the grommet!!!
In any case I will continue my visual inspection when it gets a little warmer. There are reports out there about loose wires, bad connections, etc. so I’ll check all that first. Sacrificing a chicken under the full moon will come later.
I had my husband try to light the fridge while I lay on the floor and looked inside at the glass peephole on the burner box. I could hear ticking from the relighter board but never did see a spark or a flame through that peephole. Can anyone verify that you can see sparks/flame through that when the fridge is working properly on propane? As a reminder this is the 3163 3-way with the two vents in front.
So, I’m back to the original question - is it possible to replace the thermocouple without removing the fridge? If so, does it just pull out and how hard should you have to pull?
When I removed the sparker thing I noticed a little rust on the screw that holds it in the burner assembly. There Looks like a bit of rust on the outside of the burner assembly too. I am theorizing that these fridges should be used regularly on propane to keep corrosion under control. In our case the last and only time we used it was August 2016 when camping without hookups in Vermont. Has anyone ever heard this?
