Flagpole Holder for Outback Platform?
jkjenn
jkjenn Member Posts: 6,425
I have been trying to think of some different ways to create a flagpole holder for the Outback. Has anyone come up with a solution, yet? I am thinking of something that uses ubolts for either around the bars that come up on each side, even mounting something flat on one of the sides.
  • ericnliz
    ericnliz Member Posts: 4,437
    @jkjenn, @Dalehelman made some for his handles on his T@B. I'll ask him about it at breakfast this morning. Maybe he'll do one of his picture posts with a description for you. :)
  • Verna
    Verna Member Posts: 6,876
    @Dalehelman has the best solution. A chrome fishing pole holder that clamps to the handles of his T@B.
  • ericnliz
    @Verna, Thanks & yep, those are the ones! :)
  • Dalehelman
    1. Hash  T@B Fun
  • ericnliz
    @Dalehelman, Thanks Dale, now we'll have to find somethin' else to talk about at breakfast! ;)
  • Estancio
    Estancio Member Posts: 243
    Wow, this would be a perfect way to mount my tv antenna mast!
    Stancil Campbell
    2011 T@B
    Rockingham, NC
  • dragonsdofly
    @Dalehelman, thanks!
  • Tabaz
    Tabaz Member Posts: 2,420
    Dale - What's the inside diameter of the opening?
  • Verna
    @Tabaz, here are the specs from Amazon:
    “1 x marine grade 304 stainless steel rod holder with marine grade 316 clamp-on bracket
    1 x Rubber insert (fitted)
    Tube length 230mm (9")
    Inside diameter 42mm
    Outside tube diameter 52mm
    this is product branded amarine-made“
    I had to drill out the plastic bottom so my antenna pole would fit through it. It is very sturdy, but I did not leave it on during travel. You do need a metric Allen wrench to adjust the clamp where it connects to the handle.
  • jkjenn
    edited April 2018
    I have the chrome fishing holder, too. What I don't like about it is that it is wider than the pole and does not hold the pole, itself, firmly in place. I have used pipe insulation to create a snugger fit but it moves out of place and becomes a hassle.
  • Verna
    @jkjenn, I drilled the bottom out so the pole touches the ground. Then I put ball bungies at the top and bottom of the pole holder that also go around the pole to hold it in place. It was holding for a 20 mph wind.  I didn’t risk it for the 40+ mph that were coming.
  • jkjenn
    I like the idea of drilling the bottom out. What kind of rubber insert are you using?
  • Verna
    I left the rubber insert intact, but I drilled the bottom out. By using the ball bungies, the pole was snugged up and was held tightly in place. The ground also helped hold the pole in place.
  • Dalehelman
    Estancio said:
    The bolts that came with mine look to be about an 1 1/2”. They could have been another 1/4” longer but they did work. An Ace hardware store will likely have longer ones.
    1. Hash  T@B Fun
