Has anyone replaced a 2016 3-way fridge with The one NuCamp is putting in 2018 320S T@Bs?
Photomom
Member Posts: 2,217
This^^^
I think this will be good to know for those of us with the 3163. Although, I think I would consider going to the 2 way.
Where can you buy them?
You probably won't be happy with it.
2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
How come? Not real thrilled with the one I’ve got.RollingBnB said:You probably won't be happy with it.John and Henrietta, Late 2016 T@B S Max in Western New York0 -
Gas is manual light ,like a cheap bbq, not electric and we can't drive on gas. Works great on 110v.
Alan & Patty
Southern Az0 -
Not really sure you’d want to drive with a bottle of propane discharging...TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
Isn't the ducting and venting different on the new fridges? I'm not sure if you could adapt it to the original openings, or if you'd have to do some cut and patch work on the T@B walls.
The two front vents would need to be sealed and an additional vent cut in the side. At a minimum. I suspect at some point people will start replacing the 3163s with newer model fridges. I don’t want to be the first though.ScottG said:Isn't the ducting and venting different on the new fridges? I'm not sure if you could adapt it to the original openings, or if you'd have to do some cut and patch work on the T@B walls.John and Henrietta, Late 2016 T@B S Max in Western New York0 -
@Photomom, this would be a good question to send to tech@nucamprv.com. A very nice and knowledgeable young man answers the questions sent to this email address.Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”0
