Has anyone replaced a 2016 3-way fridge with The one NuCamp is putting in 2018 320S T@Bs?
This^^^
  • jkjenn
    jkjenn Member Posts: 6,425
    I think this will be good to know for those of us with the 3163. Although, I think I would consider going to the 2 way.
  • maddmike
    maddmike Member Posts: 137
    Where can you buy them?
  • RollingBnB
    RollingBnB Member Posts: 322
    You probably won't be happy with it.
    2020 Tiffin Open Road
    2020 Nissan Versa Toad
    Alan & Patty
    Southern Az
  • Photomom
    Photomom Member Posts: 2,217
    How come? Not real thrilled with the one I’ve got.
  • RollingBnB
    Gas is manual light ,like a cheap bbq,  not electric and we can't drive on gas. Works great on 110v.
    Alan & Patty
    Southern Az
  • 4ncar
    4ncar Member Posts: 1,072
    Not really sure you’d want to drive with a bottle of propane discharging...
    Isn't the ducting and venting different on the new fridges? I'm not sure if you could adapt it to the original openings, or if you'd have to do some cut and patch work on the T@B walls.
  • Photomom
    The two front vents would need to be sealed and an additional vent cut in the side. At a minimum. I suspect at some point people will start replacing the 3163s with newer model fridges. I don’t want to be the first though.
  • Verna
    Verna Member Posts: 6,876
    @Photomom, this would be a good question to send to tech@nucamprv.com. A very nice and knowledgeable young man answers the questions sent to this email address.
