What is this thing?
I just returned from a local 2 night stay at a state park for our first trip in the T@B.
Everything went fine, but I noticed something, and I have no clue what it is.  In the clamshell galley, 2016 CS-S, there is a black, round thing between the 120 outlet, and the 12 power outlet. (that is why I put this question in this category) It has what appears to be a lens in it?  Maybe a light detector?  Any ideas?
Pictures are on my phone, will add momentarily.
2016 T@B CS-S
TV 2007 F150
  • gymcoachdon
    gymcoachdon Member Posts: 54
    2016 T@B CS-S
    TV 2007 F150
  • rkj__
    rkj__ Member Posts: 641
    My trailer does not have that.  I also don't have a TV / media system.
    Thus, my best guess is that it is a receiver for the remote control signal.  Cover it up, and see if you can still adjust your audio volume as a check.
  • gymcoachdon
    edited May 2018
    ohhh, that makes sense!  I think we may have a winner!
    I will give it a try soon.
    2016 T@B CS-S
    TV 2007 F150
  • ericnliz
    ericnliz Member Posts: 4,437
    @gymcoachdon, Smile, you're on candid camera ;) !
  • ChrisandAlexis
    ChrisandAlexis Member Posts: 120
    @gymcoachdon , we have a 2017 CS and a television in the back. I do not recall seeing that in our trailer. No guesses from me what that is.
    Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner
  • 4ncar
    4ncar Member Posts: 1,072
    Previous owner spying on ya! ;)
  • Travelin3D
    Travelin3D Member Posts: 175
    It's the optional HAL 9000 interface. "Open the clamshell door, Hal..."
    Richie, Mickie and Satchmo
    2020 320S Boondock Lite (silver w/blue)
    2019 Subaru Ascent Premium
    Daisy, Daisy........
  • Homebodyatheart
    Hard to tell from your pics, but if it’s a plug there might be wiring behind it to add USB ports. It’s the right size and location for another outlet cover. Although @Travelin3D ‘s theory is pretty good, too!
  • Verna
    Verna Member Posts: 6,876
    I seem to remember that it has to do with the Jenson, and I can’t remember if it is for the remote control or the speakers......the T@G’s had it when they first came out.....
    pthomas745 Administrator, Moderator Posts: 4,667
    edited May 2018
    Kinda looks like this, but neither picture helps:  http://www.jensenrvdirect.com/infrared-repeater-extension.html
    Basically, it seems to be a remote control "extender."  You can operate the Jensen without the remote having to be in line of sight to the Jensen unit.
  • dinzzy
    dinzzy Member Posts: 182
    That’s correct...it’s a remote eye that operates the Jenson from the outside with the remote control.   That way you can adjust the Jenson volume without getting up and going inside the T@B.
  • Clopidogrel
    Clopidogrel Member Posts: 33
    NSA?
  • gymcoachdon
    I was pretty sure someone was watching me...
    I stood outside the clamshell galley, and powered up the Jensen with the remote.  Then I turned up the volume using the remote.  Everything worked fine.  Then I covered the NSA camera with my thumb, and tried to turn down the volume.  Of course, it still worked perfectly.
    I am pretty sure that is its intended function, I will try again with tape, or another person, from farther away, and see what my results are.
    2016 T@B CS-S
    TV 2007 F150
  • dinzzy
    Russia?
