What is this thing?
gymcoachdon
Member Posts: 54
I just returned from a local 2 night stay at a state park for our first trip in the T@B.
Everything went fine, but I noticed something, and I have no clue what it is. In the clamshell galley, 2016 CS-S, there is a black, round thing between the 120 outlet, and the 12 power outlet. (that is why I put this question in this category) It has what appears to be a lens in it? Maybe a light detector? Any ideas?
Pictures are on my phone, will add momentarily.
2016 T@B CS-S
TV 2007 F150
TV 2007 F150
2016 T@B CS-S
TV 2007 F1500 -
My trailer does not have that. I also don't have a TV / media system.
Thus, my best guess is that it is a receiver for the remote control signal. Cover it up, and see if you can still adjust your audio volume as a check.
2016 T@b 320 CS-S - 2018 GMC Sierra - St. Catharines, Ontario, Canada1 -
ohhh, that makes sense! I think we may have a winner!
I will give it a try soon.2016 T@B CS-S
TV 2007 F1500 -
@gymcoachdon, Smile, you're on candid camera
! 2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf2 -
@gymcoachdon , we have a 2017 CS and a television in the back. I do not recall seeing that in our trailer. No guesses from me what that is.
Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner0 -
Previous owner spying on ya!
2018 320S Outback0 -
It's the optional HAL 9000 interface. "Open the clamshell door, Hal..."Richie, Mickie and Satchmo
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium2 -
Daisy, Daisy........Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Hard to tell from your pics, but if it’s a plug there might be wiring behind it to add USB ports. It’s the right size and location for another outlet cover. Although @Travelin3D ‘s theory is pretty good, too!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
I seem to remember that it has to do with the Jenson, and I can’t remember if it is for the remote control or the speakers......the T@G’s had it when they first came out.....Verna, Columbus, IN
Kinda looks like this, but neither picture helps: http://www.jensenrvdirect.com/infrared-repeater-extension.htmlBasically, it seems to be a remote control "extender." You can operate the Jensen without the remote having to be in line of sight to the Jensen unit.
Towed by 2014 Touareg TDi2 -
That’s correct...it’s a remote eye that operates the Jenson from the outside with the remote control. That way you can adjust the Jenson volume without getting up and going inside the T@B.Tow with a 2016 Tacoma TRD Sport, 2016 T@B CS-S Max
2 -
NSA?1
I was pretty sure someone was watching me...
I stood outside the clamshell galley, and powered up the Jensen with the remote. Then I turned up the volume using the remote. Everything worked fine. Then I covered the NSA camera with my thumb, and tried to turn down the volume. Of course, it still worked perfectly.
I am pretty sure that is its intended function, I will try again with tape, or another person, from farther away, and see what my results are.2016 T@B CS-S
TV 2007 F1501 -
Russia?Tow with a 2016 Tacoma TRD Sport, 2016 T@B CS-S Max
