Hi folks,
I’ve had a water problem in the TaB since last fall. The pump is fine and I’ve tested it by attaching a hose to it and watched it drain a bucket of water quickly. There is nothing in the filter. I pulled it and checked. The system holds prime, so not a slow air link.
If I turn the water on, I get five seconds of pressurized water flow and then it becomes the tiniest trickle.
Jill and Dale worked with me last fall, but we never got it working. (They are both amazing people.)
There is either debrie in the fresh water tank
or .... could the stack vent (if it were plugged) cause this problem?
I really don’t want to take it in, but am running out of ideas. Any thoughts you have would be greatly appreciated.
Here is a video showing the problem:
https://youtu.be/3uMXiWu-GnMthanks,
Laura
Red and White, 2017 Max S being towed by a 2014 Honda Ridgeline. Hello Mountains!
There's a vent tube that allows air into the FW tank. On my 2015 it's a clear tube that runs from the top of the tank and follows the filler tube up through the T@B and to the fill port, where it exits at a small hole just above the larger hole you pour water into.
It's a small tube, and the routing and attachment of it is such that it could get pinched or kinked along the way. If this occurs--or if the tube is plugged--it could create a temporary suction in the tank and cause the symptoms you describe.
You might try taking another piece of clean tubing, pressing it tightly over that little hole, and blowing in it. You should be able to force air into the tank with minimal effort. If there's significant resistance, I'd inspect the entire line for blockages.
(Blockages in this tube can also make filling the tank difficult as there is no way for the displaced air to easily escape.)
No guarantees that's your problem, but it's worth checking.
@ScottG also checked your suggestion....it seems clear. Thanks
FYI, here is a post on the drain screw leakage with good pictures from @BrianZ, who had the same issue: http://tabforum.nucamprv.com/#/discussion/6811/need-help-mixing-valve-leaking
Good luck!
Marc
I appreciate your your help and ideas. If you think of something else, please don’t hesitate to let me know.
I know you tested the pump in isolation, but are you sure it was operating at capacity? if the flow was under spec that could cause the problem you've documented
My only other guesses (and weak ones at that) are an air leak in the intake line between the tank and the pump, or a leak in the pump's integrated check valve. Under the right conditions either of these could cause a reduction in pump flow or pressure.
Checking for air leaks in the intake line will be a challenge given the location of all the connections. Holding off on that until I don't have another option.
I would expect the pump to cycle periodically if you had a leak on the distribution (downstream) side, as pressure would build but not be maintained as it dissipated through the leak. Your symptoms don't seem to fit that diagnosis.
I do agree that checking the intake for air leaks will be challenging. Hopefully an easier resolution will surface before then. Good luck with the mystery and keep us posted!
@LauraRey , if you allow the pump to build pressure and leave all faucets closed, then wait to see how long, or often it restarts to maintain pressure you might get some indication on whether there is an intake side leak. I don't have enough time running off the FW tank to know how long it should hold pressure, or how often it should cycle; but with all the people on here who boondock regularly, maybe they can help. Edit: Scratch that, I think that would only work from the pump check valve and in to the faucets.
Another option: I believe you mentioned you isolated the pump by drawing from a bucket. Did you, or could you do this while the distribution side is still plumbed and see if you have the same decreasing water pressure issue at the faucet? That would seem to help you isolate to the FW tank and intake hose.
Blocked vent line as suggested by @ScottG
Blocked water pickup/inlet line as suggested by @Dalehelman
Weak water pump as suggested by @ScottG
I do not suspect a leak as you would have difficulty priming the pump.
Were you able to scope the entire length of the pickup line? Can you use an air compressor set to 30PSI and blow some air through it? Do the same with the fresh water tank vent, but lower the pressure if you do.
I suppose that there could be some sludge built up on the bottom of the tank that is interfering with water pickup, but have no idea how you would test or even clean it up!
Others have already covered the items that I would question. If I was near you I'd be interested to take a look!
I totally agree.
