@Ratkity After having the Walker Tent in a box for over a month, we finally had the opportunity (and TIME...more on that in a moment) to erect it. It is wonderfully well made and provides a large enclosed, protected space. It includes all the front and side panels and curtains as seen in this picture. It does not come with flooring, so you will need carpeting of some sort. Some things to know before getting this for your 400:
1. You can only use it if the ground permits stakes. As you can see from the picture, we did not stake the walls down, just the storm straps and corners. It was not windy by the time we were finished erecting it, so we decided to forego fighting with the dozen or so stakes in the rocky ground.
2. You will need a ladder or step-stool of some sort to pull the awning along the Keder rail over the apex of the arc. I backed up my Tundra and stood on the tailgate to be able to pull the awning along the highest portion of the Keder rail. Unless you can get up to where you can pull the awning straight towards you along the rail, it won't budge (only took 45 minutes to figure that one out..once I did, the awning slid easily along the railing).
3. You need two people. If there is ANY wind of any sort, the tent will act like a giant box kite. Attempting to secure the poles that run from the trailer to the door side of the tent is not fun when the tent wants to lift off he ground!
4. The first time you want to erect this tent, plan on A LOT OF TIME (a few hours). There are a lot of parts to this tent that must be assembled (you know..."some assembly required") including clamps, poles, clips, tie-downs, etc. that, once assembled, can be left in place for the next time you use the tent. The instructions are not the clearest, but you will need them; this is not an intuitive project.
5. Be patient! It will be worth the effort. We were beginning to regret our purchase when we couldn't get the tent to budge along the Keder rail. Once we solved that, we had other obstacles to figure out, but we did and we are very glad we persevered...you will be, too!
I will more than happy to answer any questions anyone has about this product. I may try to put together an assembly video to help others navigate the instructions.
2018 T@B 400 (Rol@nd) towed by 2012 Toyota Tundra CrewMax (C@lgon)
Thanks
Can you confirm this? It looks like a fantastic enclosure (I actually like that it has no floor) but in my neck of the woods insect screening is non-negotiable!
2018 T@B 320-S towed by 1999 Chevy Suburban, Olympia WA
Here is what the new Isabella looks like:
and here's their screened window:
Ooohhhhh, this is really nice! Who is the distributor for the Isabella in Washington? I look forward to your review of the awning and thank you!
2001 Toyota Tacoma 4WD New Mexico
We've slept in 34 states, 2 countries & counting.
1. We color coded the posts and it helped a lot.
2. We can set it up as an awning, without the front and side walls, in about 10 minutes.
3. It really needs two of us.
4. We used teflon spray in the keder rail and it worked a treat.
5. Our Walker tent has a floor, it is not attached but is a good thick floor mat. You can buy them on the website.
6. We did not use the side and front as it would be really hot and we were camping the end of May in a heatwave.
7. I contacted Isabella and found out that the parts are not interchangeable. Then I contacted Walker to see if they sell screen sides. They do not, but we discussed them selling me the zippers so i could make my own screen sides. No reply from them yet.
8. I am also contemplating contacting a sail maker to see if they can take the side window and add screen to it.
9. It is a really nice tent awning but it is heavy and would be hard to put up and take down when wet. We decided to put our roof box on and store everything in it which worked well.
I'm not sure I would buy it again but we got it for a good price. In order for it to be functional in our summers I do need to sort out the screen walls. Hope this is useful information.
Would we buy it again? If we were just camping in sheltered areas and in moderate temperatures, the lighter weight (and much cheaper) tents would suffice. BUT.....we are out in all kinds of weather (including snow) and the heavy duty Isabella is up for the challenge. A small ceramic heater would warm the space up quickly. Leave the T@B door open and the A/C can cool down the T@B and the tent. For us, it's a winner. But the cost and weight may not justify a light duty use. Isabella (and Walker) tents are made for the UK and European market, where giant motorhomes don't exist. People set these tents up once for their month long vacation so they have the room to enjoy their stay. They have to be built tough for this kind of extended use (people and tents!). The lightweight nylon tents wouldn't make the cut with that kind of use. We're pleased with it.
Screen
Happy campers
Here's the old Isabella from Dutchman days. We also have the Flower Power awning and the silver awning. We will put an awning up on one side and the tent on the other...double slide-outs
Sincerely,
Diane
I just noticed where you live...yes, you'd probably be hot in the tent without A/C. We were more concerned about having a warm DRY place here in Washington
Do you know I’d this works on the CS?
The Walker and Isabella tents are "shaped" to fit the door side of the T@B (the poles and fabric). Wouldn't fit properly on back side of T@B. I don't have experience with other brands. If you are putting the kids on the back side with no entrance to T@B, you'd do better just getting a regular freestanding tent at REI and putting it wherever
You need the Keder rail to attach tent to side of T@B. I'm not sure the clamshells have the rail. Someone here will know
@madmike, there is a keder rail on the CS driver side. I wouldn’t use a tent there, but a PahaQue awning or visor works.
