Sewer Hose Carrier
13»
  • BrianZ
    BrianZ Posts: 1,770
    edited May 2018
    How did you mount the hose carrier, @leenscottfl ?
    I've been wondering if one could just use two large stainless hose clamps, and strap one around the tube & second one through that one and around the frame.
  • leenscottfl
    leenscottfl Posts: 254
    I just used really heavy duty cable ties. The carrier behind the box fits snugly enough that the ties are  just insurance.
  • BrianZ
    BrianZ Posts: 1,770
    edited May 2018
    Thanks, @leenscottfl , I think I will also try cable ties, but in combination with one of these around the tube to help grip it, cushion it, & fasten it to the trailer frame..
    I will cut it in half and put one over each side of the frame.  That's my current plan anyway, but I don't see any reason why it shouldn't work.  I feel like the rubber would serve as a bushing to help cushion it on the frame & help prevent it from sliding around.  Maybe add a second cable tie for insurance.
    If this doesn't work, there's always the screw mount option, otherwise it's cheap, easy & would save putting holes in the trailer that would add one more spot to worry about maintaining a good seal.
