Sewer Hose Carrier
How did you mount the hose carrier, @leenscottfl ?
I've been wondering if one could just use two large stainless hose clamps, and strap one around the tube & second one through that one and around the frame.-Brian in Chester, Virginia
I just used really heavy duty cable ties. The carrier behind the box fits snugly enough that the ties are just insurance.
Scott, Orange Park, Florida...2012 Jeep Wrangler Unlimited Sahara... 2015 T@B S Maxx "Buttercup". -
Thanks, @leenscottfl , I think I will also try cable ties, but in combination with one of these around the tube to help grip it, cushion it, & fasten it to the trailer frame..
I will cut it in half and put one over each side of the frame. That's my current plan anyway, but I don't see any reason why it shouldn't work. I feel like the rubber would serve as a bushing to help cushion it on the frame & help prevent it from sliding around. Maybe add a second cable tie for insurance.
If this doesn't work, there's always the screw mount option, otherwise it's cheap, easy & would save putting holes in the trailer that would add one more spot to worry about maintaining a good seal.
- 917 Introductions
- 73 Teardrop Groups & Links
