I am converting my 2007 Dutchmen T@B ro use rails and slats for the bed. Are the 5 slats in the kit enough. MY T@B seat is not reinforced and I am concerned it will sag between slats. Do the new T@B seats have a rigid bottom?
The seats are just cushions on top of the benches. The foam was upgraded by the factory in 2016, so the newest Tabs have firmer cushions. If the slats are relatively close together, there is no sag between the slats. Do you currently use only your table to support the cushions?
I think the factory slats do have gaps, but I suspect they work just fine.
Before it was standard on T@Bs, many of us made our own slats. Most versions used enough slats to fill the whole space. That's probably why you are seeing different applications.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
