Hi All,
We cooled our fridge down using AC power before our trip. We set to DC mode for the trip. By the time we got to our campsite the fridge had warmed up to 60 degrees. Our batteries are fully charged. When we got home I plugged in the T@B and cooled down the fridge to 25 degrees. I then changed to battery mode and the temp went back up to 55 degrees. I thought I might as well check the propane mode so I reset to propane and the temp dropped to 45 degrees and stayed there. So the propane mode is working but only to 45 degrees, and the battery mode isn't working at all. I've checked all the visible fuses and nothing is blown that I can see. Any ideas what the problem on the battery might be? And why does the propane mode only cool to 45 degrees when shore power cools to 25 (not that we want it that cool.)
Thank you!
Debora
Debora
2006 T16-1 U-shape and TV 2006 Ford Explorer
0 ·
Search "Fuses for Newbies" for the location of the fuses under the cooktop (there are three). It appears your TV isn't charging the fridge in transit nor is the trailer battery. The Norcold would have just about drained your trailer battery dry during the trip (at least based on my experience). Also, the fridge should cool below 45* on propane. It takes a long period of time for the fridge to switch between modes. I'd give each at least 12 hours before taking a new reading.
Photos of your fridge and a model number would definitely help us to troubleshoot. It seems that a Norcold uses a specific refrigerator model for about 3 years, discontinued manufacture of it with a new model coming out. Sometimes it’s hard to keep up with the Norcold models in the nüCamp T@B’s, and then there’s a totally different model in the DM (Dutchman) T@B.
History: Dutchman/Thor manufactured the US version (yes, there are European versions, too) from 2004 until 2010. Pleasant Valley Teardrop bought the rights to the T@B and started manufacturing the T@B in 2012. Pleasant Valley changed their name to nüCamp RV in 2017 prior to Little Guy leaving as the marketing arm. nüCamp now markets their own T@B, T@G and Cirrus Truck Campers.
Thank you!
Debora
That fuse looks very dodgy. Make sure you get a fuse of the same amperage. That fridge has 3 fuses - 1 amp, 20 amp, and 3 amp, so be careful to replace the burnt one with the correct type. Can you post a clear picture of the area where the fuses are with the burnt fuse removed? I suspect there may be some additional damage.
You can replace it with a 20 amp fuse but I would not be surprised if it blows again when you switch the fridge to battery. Make sure the battery is disconnected and the trailer is unplugged when you’re feeling around in there, okay? It’s best to turn the fridge off and take rings and watches off too.
Do the other 12 volt things in the trailer work okay?
Regards,
2016 T@B S Max (H@banero) - 2025 GMC Canyon Denali - Magnolia, TX
Thanks.
