We have the clamshell model and really like, but the bed is smaller than the non-clamshell. I'm 6'1'' so laying width wise in the bed is a bit constraining and I'd really like to stretch out. The bed is too short to lay length wise, so I'm contemplating some sort of bed extension. One of my requirements is that it be easy to move out of the way to get in and out of the T@B and for my wife to use the bathroom in the middle of the night.
My thought is to build some kind of drawer system. You can get drawer slides to support upwards of 500 lbs. I modeled up the idea and have included a youtube video of the animation. It shows the interior of the T@B with a 4'' topper for the bed. It's not a precise model, just a concept mock-up.
https://youtu.be/HWBN1Q-GzZo I saw the "Tall Guy" mod post that does something similar.
http://tab-rv.vanillaforums.com/discussion/comment/69381#Comment_69381 Thoughts? Suggestions?
Michael
https://www.walmart.com/ip/Furinno-Oxford-10060R1-Square-Foldable-Storage-Stool-Ottoman/38378250
I set it up in front of the fridge and it is almost the same height as the bed. However, we add a 2" memory foam topper to the bed so I put one of the side cushions on top of it and it is perfect. Works out GREAT!!!! No more dangling feet. I also store my clothes inside of it at night. We turn it upside down and use it as a table on the bench seats when the bed in not made...
P.S. Keeps wife from raiding the fridge at nights well!!!!
Michael
Key on my requirements list is to be able to get into the bathroom. More specifically, so my wife can get into the bathroom without waking me up! One option might be to divide the pull-out section in half so the half closest to the bathroom could be pushed in without disturbing the half furthest away.
We we currently use bedding rather than sleeping bags so that could pose an additional set of problems with this solution.
As for the bedding issue, I don't know yet how that is going to work. We actually use bags now, but intend to switch to bedding now that we have a topper. We'll likely put fitted sheets around the main bed and the extender separately then just use a loose sheet and duvet cover. We'll see how that works.
I likely won't start fabrication of the drawer until April sometime. My father in law has all the woodworking tools (and talent) but he lives in Spokane while I'm in Boise. So I'm waiting for the next opportunity to make it up there.
We had booked a site at Fort Worden for the T@B gathering last year, and were excited to meet people, but had to bail at the last minute due to work. It was too late to cancel the site so we ate the cost. So right now we're 0/1 on T@B gathering attempts.
Yes, let's keep in touch about this.
I am probably going to wait until May or so for my attempt. The T@B should be free of the snow by then.
We've slept in 34 states, 2 countries & counting.
I really liked Sawtooth's idea, probably because it was very similar to what I had already planned. Unfortunately it seems the existing front bench is already too high relative to the bed. Adding the mechanisms to be able to pull out the bed would make things worse. The next problem is that the bench is too narrow relative to the space between the bench and the existing bed. I am not sure it would be possible to find glides to span the gap. It might be possible to address all these issues, but it was starting to look like it would require rebuilding the front bench.
I really the simplicity of SAM's suggestion. Unfortunately both my wife and I require a bed extension. Therefore we need it to be wider than just the passenger-side bench.
I think there is a workable hybrid solution. In general:
1) Modify the front bench to have drawers rather than cupboards. I figure this will be beneficial even if the bed doesn't work out.
2) Replace the existing single front bench cushion with two cushions. Each cushion will have a 1/2" plywood base.
3) Replace the front-most bed filler piece (i.e. the ones from the factory that sit against the folding table to form the base of the bed) with one made of 3/4" plywood. It will be just a bit larger than the existing piece and therefore also the existing bed cushions.
When the bed is needed the drawers (1) will be pulled out to act as supports for the split cushions (2). The driver side cushion will be supported by the drawer and the replacement bed filler piece (3) . The passenger side cushion will be supported by a drawer and front-most edge of the passenger side (i.e. kitchen table) bench. The underside of the cushions will have wood strapping to ensure they don't slide off their supports.
Because the cushions are split and the drawers may be closed independently my wife may make her nightly bathroom runs without interrupting my vital beauty sleep.
Assuming this all works, point 4 of the master plan will be build an additional cupboard unit to sit on top of the front bench. It will provide a counter top, a little bit more storage, and house the split cushions when they are not being used for the bed.
My father and I are just starting on point 1. I've included some pictures below. I will keep you posted on progress, unless everything goes sideways in which case I may deny that I ever started this project!
What year Tab do you have? What kind of a bed slat did the factory provide?
The pictures below show our progress. Both drawers are in. We have mocked things up using the old cushion and a couple of pieces of plywood that are the general size of the new cushions. We are testing how the wood strips on the bottom of the plywood will “hook” onto the revised table slat and passenger-side bench. So far it looks very promising.
Overall it worked very well. I slept very comfortably (YES!) and my wife was able to get to the bathroom by just removing her side of the bed extension. The drawers are also a very nice upgrade.
On the downside:
Below are some pictures of the prototype. I did not fully assemble the factory bed portion because of other things I had in the T@B. For the cushions we used fabric that we had on hand and the final version will likely be changed to something that matches better. We did not bother to put fabric on the small piece of foam we are using to ensure a friction fit of the cushions when they are on the bench. We intentionally bought foam which made the cushions an inch or so higher than the factory bed as we put a foam topper on the factory bed.
Not only will it be easier to lift, but it should make it easier for her to reach the cushion from the factory bed.
I will play around with different placements of the loop to see what works best.
Thanks for the suggestion!
Plywood is is actually about the best, and least expensive, for this application.
So I am hoping that a correctly placed loop or two will solve the issue.
Urbana, MD
