UCamp 18 ( single dump valve mod )
Dalehelman
Member Posts: 2,414
If you are interested in this modification and you are attending UCamp 18. I am bringing enough parts to do 3 of these conversions. Total cost for parts $75. Do it yourself and save. Difficulty level is about a 2 out of 5. I will be available for help and instruction. Contact me ahead of time if interested. - Hash T@B Fun
Dale, check for PM. ThanksSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
@Dalehelman, pm also.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
I can vouch for @Dalehelman ‘s work. He reconfigured mine. It works well, and so easy to dump the tanks! Thanks again Dale!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
I can vouch for his skills as well. Love my single dump mod. I hope you’ll do this at tabazona, too. ;-))Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo)
Dale, does this mod work with the Outback platform?2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620 -
@db_cooper
yes I have done several.- Hash T@B Fun
I’d like to see how (if) this works with the front platform. The gray valve is a pain to get to.John and Henrietta, Late 2016 T@B S Max in Western New York
@Photomom
Those with the Outback platform have been very pleased. I will se if I can find some pictures.- Hash T@B Fun
I would think the gray waste gate would need to pivot 90degrees with the platform...TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
@4ncar
It can very slightly from trailer to trailer, but it is always very accessible.- Hash T@B Fun
Dale, I might be interested if it makes it easier to reach the gray valve without having to crawl around on the ground at the dump station.John and Henrietta, Late 2016 T@B S Max in Western New York
Does NuCamp offer this as a kit you can order thru Elsie? I added the platform. I bought a right angle and straight extension to my existing pipe setup. I still have the two ports then. I can see the appeal of a one hook up feature.Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI -
@TerryV6 I’ve been contemplating an extension for our black tank valve under the Outback platform. You’ve no problem with it staying connected while traveling? What’s the right angle for?John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
These extensions worked okay on our last trip. The only problem I had was when taking the hose "off" the extension started to thread off too. I probably will make them permanant if I decide to stay with this..
T@bbey Road
Appleton, WI -
Hi Dale, Id sure like to see these as well. Is this just a simple connect, or is there some cutting and relocating of gates involved?Dalehelman said:@Photomom
Those with the Outback platform have been very pleased. I will se if I can find some pictures.Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI -
@TerryV6
One cut to the gray water pipe to create a 90*. Everything else is bolt together. Entirely reversible if you ever wanted to. I guarantee you will not want to.- Hash T@B Fun
Dale, could you put me down for one of your kits?Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI -
- Hash T@B Fun
Thanks a lots!Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI -
Well... I bought our camper and said to my wife, “Wife, we are now set to do some serious camping...
Then, we decided to add a few things. Then, after being on this forum and seeing all the ideas, we decided a few more changes were in order.
Then Dale started showing us all some new ideas in camper modification. Now we are definitely set for some serious camping....
Help me me before I mod again...Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI -
Somebody needs to put a hold on your Amazon Prime @TerryV6! You’ve gone off the deep end🤣Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Funny... don’t you think???Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI -
And that rig is just for weekends.
- Hash T@B Fun
I think that’s a really classy horse trailer.TerryV6 said:Well... I bought our camper and said to my wife, “Wife, we are now set to do some serious camping...
Help me me before I mod again...John and Henrietta, Late 2016 T@B S Max in Western New York -
Dale, I am interested, assuming it will work with the platform and doesn’t involve a lot of fiddling with the pipes. Will probably need hand holding.Dalehelman said:John and Henrietta, Late 2016 T@B S Max in Western New York -
No fear this modification is completely reversible. I guarantee you won’t want to though. You would be #3. Keep in mind tanks must be empty and dry. The best way is to empty and flush. Then leave both gate valves open and the end caps off overnight or the last 50 miles or so.Photomom said:
Dale, I am interested, assuming it will work with the platform and doesn’t involve a lot of fiddling with the pipes. Will probably need hand holding.Dalehelman said:- Hash T@B Fun
@TerryV6 actually, the final mod in the pic would be a good start for storing @Dalehelman 's tools and gear! Have you ever seen his set up in the back of his jeep? It's impressive! And that's just his traveling kit!
(In his defense, he keeps an impeccably clean and well organized garage.) 2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
- 917 Introductions
- 405 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
