moving trailer by hand
any tip on to move by hand.
i had the t@g that was easy....
this one seems a bit harder to move...
    Papa, it is helpful if you update your signature line so we know what trailer you have.  I don’t think you can move the 400 by hand.  We have the 320 clamshell.  It takes 2 people and works best on pavement/hard ground - gravel is a bear.  There are trailer dollies that some owners have used.
  • Papa
    Papa Member Posts: 27
    hi sam
    how do i ad a picture of my t@b next to my name
  • Papa
    what hand brake
    edited June 2018
    @Papa, Dale is referring to the breakaway brake cable - the one you attach to your TV or hitch.
    @Dalehelman, that is smart!  I am so doing that the next time.
  • maddmike
    maddmike Member Posts: 137
    edited June 2018
    I have this that I bought to move my 20' boat around. Works even better for the T@B
    10 inch or 12 inch tires @maddmike?
  • maddmike
    edited June 2018
    I bought the 12. One of the complaints is that it is low. Good thing the T@B tongue is nice and low. On the boat I have to lower it quite a bit to reach. No issue with the T@B. Just make sure the tongue wheel is off as it can interfere when turning.
    Oh, and make sure you buy a 2" ball to go with it.
  • ericnliz
    ericnliz Member Posts: 4,437
    Harbor Freight has the same dolly at about the same price. I've had mine for two trailers now and really like the ease of moving the trailer around with it.
    @Dalehelman, Yep, I found WHOA HORSE doesn't work at all!!!! :fearful::rofl:
  • rfuss928
    rfuss928 Member Posts: 1,196
    edited June 2018
    The 12 inch is a much more substantial wheel and tire.  I think HF is 10 inch.
  • Homebodyatheart
    I have the HF trailer dolly and it makes moving the Tab by myself possible, and simple.
  • DeltaPop
    DeltaPop Member Posts: 28
    I am able to easily move the 400 by hand on a hard surface and to push it in and out of my storage building using the front roller wheel.
    Much easier than trying to back it into a narrow doorway. :)
    Don & Mary
    2018 Tab 400
    2019 Tundra CM
    Wisconsin
  • Dalehelman
    I think sometimes people are talking about moving their trailers around at their camp site by hand. We reposition our trailer by hand at most sites. That’s one of best things about aT@B the single axel makes it very  maneuverable.
    1. Hash  T@B Fun
    @DeltaPop, good to know you can manually move the 400.  I thought it might be too heavy.
  • Papa
    where can you dump waste besides at rv sites.
    any ideas
  • dragonsdofly
    @Papa, already answered your question on your thread.
  • rfuss928
    A nice big, wide jockey wheel really helps on campsite surfaces!
  • db_cooper
    db_cooper Member Posts: 749
    Moving our 320 is generally pretty easy depending on surface conditions. Sometimes a little to easy. A trick I use to insure that it does not get away if I find myself on a slight slope. I hold the emergency brake away in one hand. If things start to get out of hand I I can pull it and set the brakes.
    Wish I'd thought of this last summer!  Camping in glacier last summer, chocked one wheel, cranked the trailer off the ball, and off goes the T@b  in a circle.  I'm obviously not good at judging slopes by eye, I was sure the other side wouldn't go anywhere.  Next camp you can be sure both sides were chocked first.
    Best part though was once T@b stopped it was right where I wanted it. 😂
  • Mouseketab
    Mouseketab Member Posts: 1,262
    Papa said:
    what hand brake
    Older Dutchmen T@Bs do have a hand brake
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • ericnliz
    Just heel skid marks in the driveway? :o:s
