Thanks
qhumberd
Moderator
Hot water coming out of cold water side
Hello everyone.  I have a 2016 T@B CS-S Max (clamshell) with the Alde system and I’m having a plumbing issue.  For some reason I am getting intermittent hot water coming out of the faucet when I have the cold water turned on.  The cold runs for a second or two and then hot will run for a second or two.  The only thing that I’ve done that may have caused this is winterizing but I feel like I winterized correctly, based off a manual I found online.  Can you think of anything else that could cause this?  Bad mixing valve?  Thanks.
